Thought i'd start a new thread rather than pollute the other one, if there's a better place let me know.
MAME is quickly becoming my preferred way of emulating classic Mac OS and thanks to @adespoton I now have file sharing working using ScuzEMU (although for bigger transfers I'd still recommend using another emulator like Basilisk II to open up and modify the disk image).
My current challenge is getting Marathon running (or Marathon 2 for that matter). Most other games and applications seem fine.
I'm using a drive image with OS 8 originally cloned from my Quadra 840AV which works fine in Basilisk II. I'm also using Ample as a front end.
When I try to launch Marathon version 1.2 the screen goes black then it quits with an "error of type 16" In my other thread @adespoton suggested this was to do with the FPU. However I was mostly using the Q800 as my default system, I've also tried switching between a Quadra 650 and a Centris 650 (I believe these are more or less the same machines with and without an FPU). All of them have the same error and Marathon doesn't require an FPU, I'm not sure it even uses one if you have one...
FWIW ChatGPT says
On Classic Mac OS (like System 7, Mac OS 8, and 9), an “Error of type 16” (also known as Error -16) corresponds to:
What it means:
This error indicates that the application or the system has run out of available memory—specifically in the heap, which is the part of memory used for dynamically allocated data."
Not sure how much value to place in this and the systems have all been configured with 32 or 64MB of RAM so available RAM shouldn't be the issue.
Anyone got any tips?
I'm going to try a fresh install of 7.5.x but I think I've tried that before and had the same issue...
FWIW ChatGPT says
dsMemFullErr = -16: “Not enough room in heap zone.”
What it means:
