So some time ago I bought a PC X1950XT on the cheap and flashed it with a pre-modified FCode ROM and @joevt and I have been playing with a few PCI to PCI-E adapters and some GFX cards.
My PCI to PCI-E bridge supports 66MHz operation and in the PCI-X slots of my Dual 2GHz G5 the X1950XT preforms really well, much better than the 7800GT also in 66MHz mode.
Tho it was fun, after JoeVT modded the 7800GT ROM for Old World Mac's, to run the 7800GT in a Beige G3 upgraded to a G4.
I have not got my Yikes Lobo up and running yet for tests of these two GPU's in the 66MHz slot of the Yikes!
So the other day I picked up two dead G5 Quads, after repairing one( LCS ) I wanted to run some tests and see how this x1950XT fairs, and it does really well, but I think it has some more in it.
A quick check of the specs 580+ GPU vs 580 GPU shows we could get some more out of it.
technical.city
The core and VRAM clocks are much higher on the XT as well as 4 additional
So we really don't know what the Mac Edition GT was, we'll have to look into that, but I doubt whoever edited the FCode ROM for the XT unmasked the additional ROP's and TMU's if they are masked in the ROM and I also doubt they increased the GPU and VRAM clocks.
www.techpowerup.com
One the PC side, the XT will dominate the GT, I bet with a little work we can get the Flashed Mac XT to do the same.
X1900 GT vs X1950 XT
ATI X1950 XT vs ATI X1900 GT: technical specs, games and benchmarks.
| ROPs | 16 | 12 |
| TMUs | 16 | 12 |
X1900gt Unlock Bios Found!!!
IF YOUR GB_PIPE_SELECT IS 0x3FE4, THEN YOU CAN UNLOCK :D :D :D Long story short, there are basically two revisions of the ATI R580 core. One is referred by the engineers as the R580"XL" and the other one is known as R580"PRO". Apparently, if you swap the BIOS on the cards, IT WILL NOT WORK...
