AppleTalk over PPP with Cisco Dial-in Router
DrDeke
Do any of you remember anything about setting up dial-in equipment to support AppleTalk-over-PPP? I am trying to get this working on a Cisco 3845 for use with older Mac clients but am running into an issue where although the router successfully forwards AppleTalk packets from the dialup clients toward Ethernet-connected clients, it fails to forward packets from the Ethernet segment toward the PPP sessions, emitting errors like:
Async1/0: encapsulation failed AT packet: enctype PPP, size 34
%AT-7-DEBUGMSG: AppleTalk debug: Packet discarded,src 1.3-Unknown,dst 2.1-AEP,AEP,encapsulation failed
I've got a full writeup of the issue here including full configurations and debugging output, and would be very grateful if any of you have any insight into what I might be doing wrong. It would be really fun to get this working; I've never seen a classic Mac connect to an AppleTalk network over dialup before :).
Disclaimer: never run AT on a Cisco, only IP, so this may be wildly wrong, but:
it looks like the appletalk packet has been constructed here but stuffing it into PPP has failed, so I'd start by looking at your PPP configuration here. What do the interface details of the PPP interface look like? Is there a packet size limit/MTU somewhere that needs to be set?
edit: also, what version of IOS are you running?
Greetings,
The PPP interfaces are configured as follows:
interface Group-Async0
ip unnumbered Loopback3
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer-group 5
appletalk client-mode
async mode interactive
peer default ip address pool async
ppp authentication chap
ppp multilink
group-range 1/0 1/23
end
The MTU on the PPP interfaces has been using the default, which is 1500 bytes. I tried changing it to 512 by adding "mtu 512" to the Group-Async 0 configuration just now, and keep getting the same "encapsulation failed AT packet" errors. I'm really puzzled at this point about what the problem could be.
Looking at your stackexchange post, you've posted debug output of PPP *authentication* and AppleTalk packets, but not PPP data plane. I don't know what the appropriate incantation is to get frame-level PPP output but there probably is one: this might be worth getting.
The reason I ask is that the "encap failed" pretty much means that the L3 packet can't be shoved into the L2 frame for some reason, often because some information is missing: so I wouldn't expect you to see any sensible debug output in the appletalk debug logs, you'll need to look at the PPP logs.
Why didn't I think of that?!
The available debug ppp options on the router are:
ypsi-c3845-1#debug ppp ?
authentication CHAP/PAP/MSCHAP/EAP authentication
bap BAP protocol transactions
cbcp Callback Control Protocol negotiation
elog PPP ELOGs
error Protocol errors and error statistics
forwarding PPP layer 2 forwarding
mppe MPPE Events
multilink Multilink activity
negotiation Protocol parameter negotiation
packet Low-level PPP packet dump
I started off by turning on debug ppp error, debug ppp forwarding, and debug ppp packet. With these options enabled, when I sent AppleTalk packets from the Mac over the PPP link, I got output like the following:
Feb 4 18:32:05.463: As1/1 PPP: I pkt type 0x0029, datagramsize 34 link[appletalk]
Feb 4 18:32:06.211: As1/1 PPP: I pkt type 0x0029, datagramsize 34 link[appletalk]
Feb 4 18:32:06.951: As1/1 PPP: I pkt type 0x0029, datagramsize 34 link[appletalk]
That makes sense to me; 0x0029 is the PPP protocol field value for AppleTalk. Unfortunately, when attempting to send AppleTalk packets from an Ethernet-connected host through the router over the PPP link (as well as from the router itself over the PPP link), I got no debugging output at all.
At this point, in case I was misunderstanding any of the available debugging options, I tried turning all of the PPP debugging options on:
ypsi-c3845-1#debug ppp authentication
PPP authentication debugging is on
ypsi-c3845-1#debug ppp bap
BAP general debugging is on
ypsi-c3845-1#debug ppp cbcp
PPP Callback Control Protocol debugging is on
ypsi-c3845-1#debug ppp elog ?
cps PPP elogs to measure cps
detailed PPP detailed elogs
keepalive PPP keepalive elogs
negotiation negotiation elog
ypsi-c3845-1#debug ppp elog cps
PPP Elogs for measuring CPS debugging is on
ypsi-c3845-1#debug ppp elog detailed
PPP Detailed Elogs debugging is on
ypsi-c3845-1#debug ppp elog keepalive
PPP Keepalive Elogs debugging is on
ypsi-c3845-1#debug ppp elog negotiation
PPP Negotiation Elogs debugging is on
ypsi-c3845-1#debug ppp error
PPP protocol errors debugging is on
ypsi-c3845-1#debug ppp forwarding
PPP forwarding events debugging is on
ypsi-c3845-1#debug ppp mppe ?
detailed MPPE Packet Details
events MPPE Events
packets MPPE Packets
ypsi-c3845-1#debug ppp mppe de
ypsi-c3845-1#debug ppp mppe detailed
MPPE Packet Details debugging is on
ypsi-c3845-1#debug ppp mppe events
MPPE Events debugging is on
ypsi-c3845-1#debug ppp mppe packets
MPPE Packets debugging is on
ypsi-c3845-1#debug ppp mu
ypsi-c3845-1#debug ppp multilink ?
data First bytes of multilink packet
events Multilink events
fragments Multilink fragments
ypsi-c3845-1#debug ppp multilink data
First bytes of multilink packet debugging is on
ypsi-c3845-1#debug ppp multilink events
Multilink events debugging is on
ypsi-c3845-1#debug ppp multilink fragments
Multilink fragments debugging is on
ypsi-c3845-1#debug ppp negotiation
PPP protocol negotiation debugging is on
ypsi-c3845-1#debug ppp packet
PPP packet display debugging is on
Unfortunately, this did not produce any relevant additional output. Out of desperation (and in thinking that there should be some additional debugging flags that might shine some light on this problem, but not having any idea what they might be), I tried running debug all. The router crashed a few seconds after I did that (despite having very little activity going on). I will power cycle it and try it again, but am less than hopeful that it will help.
Sorry, lost track of this thread. Not that I have much useful to add. :-/
The part of me that used to run Cisco stuff in production instinctively winced at this :-D.
I have just successfully implemented a local ISP for use with the old telephone connections in my home.
Hardware used:
Cisco 1841 (IOS 12.4) with two WIC-1AM modem cards
Cisco VG204XM VOIP gateway (4x FXS)
The 1841 is configured based on the configuration here
The VG204XM is (at the moment) configured as a simple group where all ports are just connected to each other (phone-numbers 1001-1004)
It was a bit of time to understand the syntax of IOS since i have never done any configuration of Cisco devices up to this moment. I am currently running a test-setup and have connected the boxes directly together with short cables. In the end, it just began to work after i replaced the short RJ11 cables with new, longer ones that i crimped myself. To me it looks like the cables have to have some length for the systems to work reliably.
I am currently able to surf the web from an iBook G4 from its integrated modem at 33.6kbps
Accessing my local lan is also possible (as well as afp) and i am very happy with the result so far.
My goal is to get the VG204XM connected to my internet router (fritzBox) which allows to connect SIP VOIP clients.
I had tried that at first but the configuration is more complex than i had thought (although there is a guide on the web).
The config-files i uploaded here are just for reference. This works for me but may need some (or a lot) of modification for other people.
Im from Germany and some configurations may be specific to my country.
Working:
Dial-in to local network over ppp using a modem with access to the internet.
ToDo:
Getting the VG204 VOIP to work with my internet-gateway.
Getting the 2nd. VG204 connected to the 2nd. modem for 6 available phone-lines in total
Getting SLIP to work reliably
Getting 56K to work instead of only 33.6kbps
Test FAX compatibility
Test latency and speed
Cost:
Cisco 1841: free (was part of a retro haul from Years ago)
Cisco WIC-1AM (2x): 16€ + 16€
Cisco VG204XM (2x): 50€
old Telephone (2x): free
cables and stuff: free
total 82€
Nice! If you set up an Asterisk server, you can even hook up your POTS system to the rest of the world via VoIP! The bridge won't handle digital networking or fax of course, but it'd be neat to be able to call someone over the internet with a rotary phone!
I revised the my setup and used a PABX with 3 FXO and 8 FXS to connect the 3 FXO to a VIOP gateway. The gateway is a simple Fritzbox that maps the 3 telephone numbers to the 3 FXO ports. The 1841 is connected to the PABX and i get 33.6KBps modem-2-modem over VOIP i get 20KBps. I have yet to try connecting to a modem on the telephone net.
The PABX is nice since it allows me to have a completely analog layer before i have use VOIP. It is quite low power and allows for flexibility. I want to modify the system a bit to have the analog phone lines of the FritzBox directly connected to the PABX that would reduce the ceomplexity a lot while still allowing DECT, FAX and Modem to work.
I also realized that even with V92, i would never get 56KBps without using a digital modem setup which is not really realistic.
-Jonas
