@luRaichu had asked in a profile post about swapping the circuit board from a SuperDrive to an 800K drive to convert it. I know from personal experience that won't work because at the very least the chassis is slightly different between the two and it won't fit.
However, I've swapped the head assembly from an 800K to a SuperDrive before, and it seemed to work fine.
But @nyef said that the head density is different, and I'm inclined to believe that's true.
I don't want to give any bad advice, but has anyone else done this? Or did I just luck out with my frankenfloppy?
The heads LOOK like the same part between the two drives.
If anyone else can confirm, then that could be a fix for luRaichu.
