Hey Everyone
I am working on a Quadra 700 that was battery bombed -- I managed to fix it so it chimes (good chime) but still I cannot get any video out from it. I already checked several similar posts (https://68kmla.org/bb/index.php?threads/quadra-700with-no-video-output.46895/) and went ahead and checked all connections against the schematics and everything seems fine.
I checked most of the internal connections on the DAFBII, vram, RAMDAC, etc and everything checks out.
I went ahead and checked all the clocks and found that the VIDCLK that should come out from the RAMDAC (357S0010-A) and goes in into the DAFBII is basically dead.
From the DAFBII_ACDC doc:
ACDC Video CLUT/DAC Schematics (357S0010-A) --> VIDCLK is an output here and is dead.
Schematics of the DAFBII:
I am assuming the ramdac is dead as when I turn on the machine it gets kind of warm and as mentioned above there is no VIDCLK sitnal.. YET, I tried out an external video card attached to the NUBUS and still I dont get any video
Does anyone know if the RAMDAC is necessary for the video overall to work? or with an external card it should just work.
Also, does anyone also has a technical document for the RAMDAC similar to the DAFBII?
I checked connections 5V, gnd, etc and everything is connected where it should, any other thoughts ?
