Hi all,
My trusty Apple IIgs RGB display is starting to show its age - it works (mostly) but the image starts flickering wildly after it warms up (literally - this display gets quite hot after a while!).
I'm already planning to do a bit of solder reflowing just in case it's a cold solder joint that's causing the issue, but I've also ordered a full set of replacement capacitors from Console5. All the other items I've recapped to date were pretty well documented, including some nice beginner-friendly capacitor map images I could refer to while doing the work. Unfortunately, I've had no luck finding a "cap map" for this display - if any of you have one, I'd be grateful for a link or hookup!
Huxley
Huxley
