I just acquired a Mac 512k with a Levco MonsterMac plus SCSI.
I was actually surprised at the size of the metal box that holds the disk drive and power supply.
It takes up the entire right side of the machine and barely fits. It is quite heavy and bolted into place with two pressure plates and a screw.
I was also surprised to find an Apple Quantum 80S SCSI drive next to the SCSI power supply inside the metal box structure.
The machine boots and works but the SCSI drive does not.
The Levco SCSI draws power from the Analog board with some clips and the SCSI interface plugs directly into the Levco board which plugs into the 512K logic board.
I've been trying to learn as much as I can about these 'monsters' but there really isn't a lot of information that I could find. I do believe this is a later version because it has the version 2 and 2.1 ROMS. But, again, I have no idea...
The 512k shows 2mb of RAM after booting. The internal floppy works, but the external floppy port does not. I am booting the system with my Floppy Emu from the internal FDD port. The Floppy Emu is not recognized on the external port. I read somewhere that the external FDD is hijacked or disabled by the Monster Mac, but I don't know if that is true. There is also a SCSI port cable that runs from the internal HDD out thru a hole in the back of the case.
My short term plan:
Clean this thing up.
Recap the analog board.
Make sure the main Levco board works properly.
Go after the SCSI.
Any advice or experience with these things would be appreciated.
Thanks!
My short term plan:
Go after the SCSI.
Thanks!
