It does chime.torn display cable? maybe a bad interconnect cable?
idk, does it chime?
I'll check those out. I have no battery, so I'll examine those.Pull the main battery out when restoring any 1x0 PowerBooks, they usually need some coaxing to run with them in. Your LCD error is either the LCD ribbon cable or the Cpu daughter card isn't fully pushed down.
That's what I'm thinking, but where? It also appears that the cable pins direct to the small board.Perhaps get a new ribbon cable (from a donor laptop)?
I don’t recommend this approach as the original ribbon cables are failure prone.Perhaps get a new ribbon cable (from a donor laptop)?
That would be nice. How much for a good one, shipping to Virginia?Hm, I haven't really seen that... I have a few interconnect boards (with attached ribbon cables) and they all seem to be working ok.
