Dear all,
I am a Mac user from Hong Kong. Recently I get a Macintosh II ci and I am going to restore it.
Here is the image of the board. It seems clean and fine. I replaced a DIY power supply by folloing instructions from MrGasS. To play safe, I did the modification on the ATX extension cable.
I also use a Blue SCSI clone at the back. It works on my Macintosh FDHD. There are some "pulse (green LED flashing)" after turning on the Macintosh II, indicate that it is loading from the SCSI. The front LED is on, the keyboard seems work as well because the CAP lock LED is on if I press the CAP lock button.
I use a DB15-VGA converter to connect my Eizo L367 display. (Left, for reference only.) Unfortunately, there are no video signal and no sound when turning on the Mac II ci.
Can anyone suggest me what may happen.
Thanks a lot.
Thanks a lot.
