I recapped the analog board of a Mac 512. All worked fine. After it was stored for a couple of months, I started the Mac again But this time, the CRT would not turn on. There was a solid boot chime/beep though. Voltage on the 5V and 12V/-12V rails were normal.
Troubleshooting done so far:
- moved the brightness know back and forth, waited a few minutes for the CRT to warm up
- Re-checked the solder joints of the flyback transformer and the CRT cable
- Checked the Q2 resistor (on some boards this seems to be the Q3 resistor). I could not measure a short. This was done following a tip in "A Dead Mac Scrolls" from this PDF.
Any other tips where to check next?
