I am currently in possession of an SE/30 with a Cabletron Ethernet card (AUI + ST media) running System 7.5. I've downloaded the cabletron.sit driver file from the Vintage Mac Museum repository. While I have been able to get the installer copied over to the system I cannot get the driver itself installed. Whether I install from a floppy disk (obviously not the original) or off the hard disk, it insists on needing the "Ethertalk Installer" disk. I've named the diskette "Ethertalk Installer", but that was just a shot in the dark that didn't work. The Cabletron Ethertalk Installer folder extracted from the cabletron.sit file appears to contain everything I would need, but perhaps there is another disk that I'm not accounting for...? (I even have tried other vendors' Ethertalk Installer images, but this doesn't work, either... no real surprise.)
As far as I can tell, the hardware works (link and activity lights are functional on the AUI port) but the driver isn't there. Not sure if there's anything else I can/should try at this point. I haven't attempted an OS upgrade/downgrade/reinstall, as any install via floppies will take time to set up, plus I'd actually need to acquire a couple dozen floppies themselves for System 7.x. I am willing to put in the effort to go to 7.5.3 if it'll streamline the driver install process.
This was an eBay purchase that I'll need to return in the next two weeks if I cannot get Ethernet working. I believe the SE/30 of my past ran MacTCP with an Asanté card, but I don't have prior experience with a Cabletron card.
Any advice would be helpful. I'd really like to hold onto this machine if possible and make it a permanent part of my vintage hardware collection, but I'm rather insistent that everything is able to talk IPv4 on my LAN.
Thanks,
G
Thanks,
G
