Stapler: I remade a 32 year old classic Macintosh app
I still dream of this weird task-based way of working, with apps like Stapler (1992, Patterson Software Works) and LaunchList (2009, Ali Rantakari) so I made my own take for modern macOS.
You might like it because you will discover the classic Stapler app!
Cheers!
matt
Cheers!
matt
so, was it "aliases before aliases" or am I misreading it?
Sorry, I'm not totally clear about your question so forgive me if I'm answering the wrong thing.
But classic Stapler was a wrapper for System 7 aliases, much like my modern Stapler is a wrapper for macOS security scoped bookmarks (they are the most modern form of aliases)
HTH
ps: I just added support for macOS 12, will release a new version soon. I know many people (usually me) hold back a few versions of macOS.
'Aliases' under System 7 (and later - even now!) can mean two things: a data structure that contains all the information the system needs to find a file, and a file that contains that data structure (an alias file). The aliases the Finder creates when you do Create Alias is the latter, it creates a file that contains an alias data structure.
But you can store and embed aliases in other ways too - it doesn't have to be within a dedicated alias file. Stapler kept a set of alias data structures inside its documents, so it's a kind of front-end to the Alias Manager, just as alias files are also a front-end to the Alias Manager. It didn't come before the alias manager; it used it in exactly the same way that the Finder did.
Modern OS X, mongrel that it is, retains this dual character of aliases. So @gingerbeardman's new Stapler acts as a front-end to the strange mutated descendent of the Alias Manager that exists in modern OS X, much as the old one acted as a front-end to the System 7 Alias Manager.
(I hope that answers the question you asked?)
