Your FPU is fake unfortunately, but that CPU is legit and will work nicely. I'd just leave your original FPU in there; the diimo SE/30 only runs FPU at 25mhz for some reason so any 68882 will work fine.
poo. Oh well ebay refund on it then I guess. Less work replacing only one chip hahaha.
I've worked out what the issue is with the floppy.
Use the SONY CR-44 PSU as a frame of reference for the voltages and minimum Current output you will need: +5V: 6.0A +12V Sweep: 1.25A +12V Disk: 2.1A -12V: 0.5A Sweep and Disk are not isolated, so you could drive both with a single +12V power line rated at 3.35A or higher. And no, a -12V...
68kmla.org
Discussions on PSU replacement. Not necessary to read. The important bit is
@JDW s post on original SONY PSU which is what I have:
+5V: 6.0A
+12V Sweep: 1.25A
+12V Disk: 2.1A
-12V: 0.5A
Sweep and Disk are not isolated, so you could drive both with a single +12V power line rated at 3.35A or higher. And no, a -12V line rated at 0.3A is not acceptable, in my opinion, since the -12V line of the SONY is 0.5A.
With the above in mind, I have replaced the sony with the pico adapter from dekunukem and a 150w pico. SO. Floppy failure would suggest that the floor box/power converter from an XBox 360, although having 135 watts, is a bit puny on the -5v rail at 1A (As far as I can find out) and probably doesnt have enough go for the 5 and 12 either. But thats what my recapping person has and is using to test, But I'll send him over a proper 12v 12A rated Power supply which is correct for the pico.
Basically not enough oomph (its not the PSU or the adapter) it is the rail supply, or box on the floor. Problem should then hopefully be solved. But a recap for the card, wiring loom etc will of course help. I'll bundle it all off to him.
If I'm wrong I'll be back here to moo about it, but that "explains" it. Will wail at ebay about the fake 68882.
