Hi all!
I have a gorgeous iMac G4 that I was able to find (with difficulty) where I live late last year, and I've been enjoying it a ton since getting it. I have replaced its fan with a Noctua one, upgraded its stock CD drive to a DVD one, and have a basic IDE to mSATA adapter in there to replace its original hard drive. Other than that, it's stock with no work done to it — well, other than a lot of elbow grease to clean it as best I can. Pretty sure the previous owner used it in a rather dusty and possible somewhat smoke-filled environment, judging by the dirtiness it had inside.
Last weekend I opened it up again as I wanted to apply fresh thermal paste on the CPU, something I didn't do last time around. I also took the opportunity to replace the conductive pads on the bottom of the motherboard. I felt like it may have been running a bit warmer than I'd like when playing through the Age of Empires campaign, which is what led me to do this all now.
This time while I was in there I noticed two electrolytic capacitors that have some light cracks showing, and near it some spools of some kind (apologies, I'm not an expert and lack familiarity with all the necessary lingo) have some edges clipped off too it appears. I am not too familiar with how these types of capacitors might show trouble as I've usually seen us replace other types with these
. Do you think these are signs of them on their way to failing, or is it mostly just an aesthetic thing, or something else? I can't help but feel like these look like they may have some sort of plastic(?) coating on them as opposed to the other capacitors seen around these, they appear a bit more "shiny." I could be way off the mark here. I should have tried to make more photos while I was in there, I do hope the one I have is of some help already.
The iMac is operating perfectly fine from what I can tell, with one exception that I'm not 100% sure is actually an issue or just how it always worked. The best way I can describe it is: when playing back audio over the Apple Pro speakers (though I believe the same happens with the tinny internal one), when only some softer sounds are playing you can hear there's a sort of cut-off level and some of those sounds are not played back, or partially played back in case there is a fade-in for example. It doesn't happen when it's actively playing back continuous audio that's above this supposed threshold, it really only happens with soft (or, at lower volume) individual sounds basically.
If it is an issue, does anyone happen to have a link to a site/thread that has more details on the iMac G4's components? I was so far unable to find a parts list.
Thank you kindly in advance for any tips or advice you may be able to provide!
