Hello, new to the community. I found this old Mackintosh, I think a Lisa 2 or Mackintosh XL. It doesn't have a keyboard or mouse unfortunately, but seems to have an expansion board of some kind inside. Can anyone help identify it
I would like to clean it up and get it going, but I don't plan to spend thousands on original accessories... is there a modern mouse / keyboard, or a reasonably priced reproduction I could get to test it? Will also need a power cable as there is nothing with it - are any power cables that size that fit going to be ok, or it needs a specific power cable?
Thanks, I assume it's a relatively generic machine but would like to see if I can get it going. What would be the best approach to restoration, cleaning and any dumb moves to avoid for the best chance of getting it going and not frying it straight away?
Cheers, D~
Cheers, D~
