I recently acquired an SE. The floppy wasn’t working, so I got it out and lubed everything and replaced the wet-cardboard eject gear, which had stripped. The drive takes in disks now, but I always get the message “this disk is unreadable by this Macintosh”. I get this same result from any floppy, including the original system disks. I inserted a blank disk and selected the “initialize” option. The heads moved, then the disk was ejected. The heads touch if the carrier is put in the loaded position, but could they be misaligned
somehow? I’ve attached a video fwiw
