Macintosh TV - Tuner Software/Drivers
Hello fellow 68k'ers!
I just managed to pick up a Macintosh TV in incredibly good condition.  Everything works great - and now that I have gotten past the problem of installing Stuffit (so I can actually decompress older 68k software!).
Here's the problem: Whoever owned this computer before must have wiped the hard drive and put a clean 7.6 OS install onto the computer before selling it.  As a result, I think I may be missing the necessary TV tuner software and drivers.  No matter what I do I can't switch to TV mode!
I'm fairly certain that this is not a hardware issue, as I have opened up the unit, cleaned it, checked for damage/age related issues -- and the hardware looks good.
Any idea where I can find this mythical software?  I've considered buying an Apple TV Tuner card and using the drivers on the CD that comes with it -- but don't know if this is the same thing and will do the trick.
Any feedback appreciated.
There's nothing mythical about the software. It uses the Apple TV/Video system. I believe from system 7.6 onwards it was included on the system install media and for 7.5 you got it on floppy discs with the Apple TV/Video System.
It used to be available on the Apple FTP but that's long gone now and the folks here on the forum who archived it don't seem to advertise where the heck they  make their copies available online.
I can look on mine later today and let you know for sure but I want to say there is a control panel for TV that you can setup hotkey to switch into TV mode you simply hit that and it switches over to TV. It will not display in a window or anything like that how the power macs do.
Wish I could help, mine came with the original install CD so I didn't have to go scrounging.  However, the 7.6 installer I have worked with the TAM and TV functions, so I would think it would be in there already.
Apple Video Player is universal in that all the device hooks for the AV, tuner and FM radio cards are in the program itself and when it detects them it adds them to its list of selectable devices. You don't need machine specific drivers to use its onboard A/V functions either.
Apple video player does not work with this. You use the "TV Setup" control panel and then switch to TV mode, it doesn't work like the later AV inputs on newer machines.
From what I remember when I had one of these, it can either be in TV mode OR Computer mode but there was no bridge between the two.  Like you couldn't import or record video from the tuner on to the HD.  I remember saying at the time "I wish there was a way to record video to the hard drive, we wouldnt need VCRs anymore".  But yeah, It was either on one mode or the other, no connection between the two.
As a side note, with analog broadcasting long gone, aren't the TV portions of these things pretty much useless?
depends , best thing is VCR connected to it as it will have analog signal.  Digital to analog Converter boxes can be had cheap at goodwills, so it can still be used.
