Thanks, I think finding a Kittyhawk may be a little difficult but I'll keep an eye out now that I know what to look forLooks like a HP KittyHawk. A 1.3in form factor that didn't catch on.
HP Kittyhawk - Wikipedia
en.wikipedia.org
Gender changers are readily available, but they're not straight through, you need to cross the traces over.Given the timeframe of the Focus card's release, Alltech likely got a whole bunch of those drives surplus for cheap. The header looks like it was modified or replaced. A pin header/gender changer for the DOMs is doable, just cut some of these down to size: https://www.ebay.com/itm/141182458139
If you buy one from abroad, is it a Non-dom DOM?Until a few hours ago I'd never heard of a DOM and now they're all the rage!
Brilliant! I was trying to think of a good DOM joke, but this one is inDOMitable ;-) !If you buy one from abroad, is it a Non-dom DOM?
I think you're misjudging the size of a DOM - they are about 25mm long. Combined with an adapter, about 40mm long total.The IDE DOM with the gender changer adapter is likely going to be as long or longer than a 2.5” SSD and I have those on hand
Good point. You'd need an adapter, I can see they can cost as little as £4 on eBay (+P&P); and small CF cards can be bought for about £5-£6; whereas a 512MB DOM from eBay would be about the same (£10 inc P&P).Why should you use a DOM module when a CF card also works?
On a motherboard, they plug straight into the IDE connector. No cable, no adapter board.Why should you use a DOM module when a CF card also works?
Dom's are very interesting. I've never heard of it before.
Micky
