Some old school mods!!!
Some people hated the compact Mac obviously. These are 512k boards with a homebrew VGA adaptor in an old PC type case. I haven't tested them yet. Pull apart and clean/inspect then see what happens.
That's really cool! I remember seeing these on eBay I think. If you can get them going do post it on here! Would love to see them in action.
You don't see many of those in the wild! I think those used to be called "cat macs", for "catalogue", because you ordered the bits from catalogues then put them together yourself. There's recipes for this kind of thing in the book Build your own Mac and save a bundle (or words to that effect). That book is oddly useful these days because it tells you things like what connectors are used in the early Macs, saves a lot of staring at datasheets..,
That graphics output will not be VGA, though - while I can't see enough on the more complex board to see what it's doing properly, there's no way two 74 series logic chips is enough to retime the Mac's video signal to VGA standards. So don't be disheartened if you plug it in and you don't get video - you may well need a forgiving scaler or rgb2hdmi or something on the output.
I saw the auction too but forgot about it; glad you scored it Fred! The video out is probably Monochrome TTL (aka Hercules), not CGA, these monitors are really hard to find.
Yes, it'll be monochrome TTL. The timings and resolution will be weird. If you look in Build your own Mac and save a bundle that gives examples of some screens that work with it, IIRC: or, again,use an rgb2hdmi or similar.
Yes Your right need to do some research on TTL to VGA? or some such
This device might do what you need - a Raspberry Pi Pico to TTL/CGA/EGA converter, was cheap and used to be sold as a complete kit but maybe not now, still looks impressive.
Another product here but pretty expensive
It can be purchased here
Those are a nice find. I’ve never seen any for sale.
What are your plans, once you have video output?
It looks like some better cable management wouldn’t go amiss, as it currently looks like the engine bay of an old car. But in a way, it’s nice to keep them as they are…
You may or may not end up having to repair or replace the power supply they used. A Mac logicboard is easy to power, and a modern replacement (e.g a Seasonic or MeanWell) unit is going to be more efficient and safer than the old unit. The ‘heat sink is live’ warning sticker there is … well, I’m glad the warning sticker *is* there, but it still leaves me feeling a bit ‘eh’ that it’s live at all.
This isn't at all uncommon. One of the heatsinks on the normal plus AB is live. Someone did once explain to me why - there is a good reason for it - but I cannot for the life of me remember why. It's still the case in quite a lot of modern PSUs. This kind of thing is why you shouldn't poke PSUs unless you're very sure you know what's going on.
I did know about the Plus analog board having a live heat sink but I wasn’t aware it’s still the case in modern PSUs too.
In any case, I guess OP should assume the worst when it comes to that power supply - I get the feeling it hasn’t been powered up for a long time.
I guess…Turn it on at a distance with a long wooden stick right next to the plug socket so you can kill power if apocalypse happens?
