Unfortunately I think that is the one variant Androda doesn't make. Might be worth reaching out and seeing if he would be willing to add it to his flex cable recreations. https://androda.work/product-category/macportable/
That's the odd part, they have the bigger version which seems to be identical in everything but size, but no sign of the smaller one even existing even going back to older catalogs.
It's possible something like HARTING 15290262501000 or 15290262502000 might fit (or be modified to fit) but I don't have any on hand to test.
Unfortunately i know.. i took the bigger version from usa (i'm in europe) and when the package arrived... surprise! I'm start to thinking of soldering wires one by one directly on the display pins. It's a shame my portable can't live anymore because of a stupid cable
Well if you can desolder the connector on the display board you could probably use a direct board IDC crimp like 3240-26-00, M50-3801342, or FFMD-13-01. The cable wouldn't be detachable from the display anymore but at least the other end would still be.
Find many great new & used options and get the best deals for Apple Macintosh Portable 5120 LCD Screen Display Ribbon Cable at the best online prices at eBay! Free delivery for many products.
