Yes, there is a separate 2010 patch by Avi Drissman for MessagePad 120/130 devices running NOS 2.0.The Y2K patch works on mp120v2 and mp130 as well... but there was some caveat I ran into before. Can't remember what it was anymore.
I did that when I owned a MessagePad and my original power supply wasn’t working properly: the modern replacement PSU didn’t work! The MessagePad seems to be very picky about the exact input voltage: it gave me an error message (don’t remember exactly what it was) and straight up refuse to charge with the modern PSU! (in the end I was able to fix the original power supply)I don't remember the diameter of the barrel connector but it was either 2.1mm or 2.5mm. I don't see the specs for the power supply on Wikipedia which is odd because it should be but here goes:
Voltage spec: 7.5V DC
Polarity: Center Terminal Positive
Barrel outer diameter:
Pin diameter:
Pretty sure you can spec something like that from Mouser or Jameco or Digikey. Polarity I'm not so sure about though, but that can be fixed.
that is sadly the fate of every one of those rubberized coatings that were so popular on electronics.The soft plastic coating can break down with age and become sticky and unpleasant to the touch. I don’t know if it’s fixable, especially long term. (It happened with my MessagePad 2000, ended up selling it because of that)
