So, there are a couple of ways of modifying Startup Screens that I know of.
On older OSes (pre System 7.5 era) you can edit the icon and text string (it's a pascal string, so keep it the same length or modify the length manually).
On "Mac OS" type systems there are a series of pict resources you can edit.
On all Classic OSes I've used, you can put a file in the system called... StartupScreen with a pict resource and it draws it over the top during boot.
What I'm wondering though, when I modify the stock Pict from System 7.5 or later it loads really slowly. I'm guessing Apple's stock image is a MacDraw style pict with multiple elements including vector objects? Me editing it is putting it back as a single bitmap. Does anyone have any suggestions how best to edit it and keep the original vector content so they draw as quickly as the stock image?
