ADB Optical mouse by Kensington
Today I was going through boxes from the great haul of 2016 and came across this mouse.  It's a Kensington mouse, but it's optical!  :-O
It looks like a regular Apple ADB cord, and there's no labels on it.  It is fantastic!  I love this mouse.  Anyone know what model it is?  I'd like to find more, but Googling Kensington ADB optical mouse doesn't lend any real results.
It is a nice thing to have.
Nowadays, it is as easy to get one of BMOW's USB-ADB adaptors and use your USB mouse of choice. Mine is the Microsoft Intellimouse from 2000.
Yeah, I bought a Wombat from BMOW a while ago, but I have to say I love living the dongle-free life with this little guy!
View attachment 16170View attachment 16171
Very cool!
Is it just me or does anyone else notice a mismatch between the ADB cable and the mouse?
Can it be that an ADB cable was stuck into a laser mouse?
Platinum grey was most definitely out of fashion in the late 1990s. This mouse would have had a white or translucent USB cable.
Here is a picture from one of the links above for the Mouse
And this picture is from Archive.org for kensington.com for the Mouse•in•a•Box.
I bought one of these and it came with a ball, alas.
The PDF for the Mouse•in•a•Box Family is also here.
Final thought: you might just very well have Kensington's development model of an ADB optical mouse!
Do you know the model number?
229822
The mouse has a USB-A connector, and there's a proprietary adapter with a female USB connector and a male ADB connector that only works with this mouse.
That's interesting to know that it only works with that specific mouse.
Now I want to see the board inside the mouse LOL
That sounds like some mice in the early 2000s that had a USB-A connector and a works-only-with-that-mouse adapter to PS/2.
Didn't Kensington also make a hybrid USB and ADB trackball with a similar adapter? I wonder if the adapter and circuitry are the same between the two products.
Yeah, I've seen some PS/2 mice that contain a "USB" microcontroller and optical sensor. They just fall back to PS/2 after a couple seconds of not getting a USB poll, or probably after getting a PS/2 reset. Probably the same thing is happening here, or the ADB cable has a magic resistor in it to hint to the controller which mode to be in.
Here's an example one, the PAW3515DB: https://www.alldatasheet.com/datasheet-pdf/pdf/558660/PIXART/PAW3515DB.html
That definitely doesn't look stock, most likely modified. It'd be interesting to see what's on the inside.
For completeness and future reference, I reverse engineered the pinout back to the two microcontrollers on the mouseboard or the Kensington 64210.
The MiniDin8 breakout cable pinout is:
Pin 1ADB Data
Pin 2ADB VCC (5V)
Pin 3USB VCC (5V)
Pin 4USB DATA-
Pin 5USB DATA+
Pin 6GND
Pin 7NC
Pin 8NC
