Greetings,
I have three TDK PSU’s from various LC’s.
I’ve recapped all three. All had low voltage and wouldn’t power on my LC II.
After recapping, two of them work perfectly with the correct voltages and power my LC II without issue.
The third shows correct voltages on the 5 volt side but the 12 volt rail has jumped to 18 volts.
I replaced ALL of the caps and have double checked polarity but everything looks right.
Why would the 12v voltage jump so high?
Thanks in advance for you help!
