You’ll need to use the drive on a 68040 Mac, using FWB HDT 3.0.2 with 7.6.1 if you can, and delete all partitions that were made including any drivers the software installed on the root hidden partition.
Did you ever make any progress on this issue? I picked up a couple of 640 drives from Japan for cheap. Most Adaptec SCSI PCI cards were Mac Compatible. I have several.Cory,
Usually unmanaged gigabit switches from the more budget area of pricing are more difficult to connect with older Macs. At work I use Netgear managed switches for this reason, and I stipulate 10Mb on those ports I have old Macs on. Not so much now but we used to have many IIsi machines with 68040 cards and MacCon Ethernet. Those did not work on off the shelf budget gigabit switches in my scenario.
This is a bigger issue than just myself. I’ve helped a few people last year on Reddit who couldn’t connect their Mac to their networks at home by suggesting an old 10Mb hub or switch or router in between and each time I’ve been thanked because it made it all work.
Ideally I’d have a large work and display area for my vintage Macs at home, with several cable drops for Ethernet, a LocalTalk bridge for those that don’t have Ethernet, and a good test station for machines I’m working on.
Back on topic I am actually eagerly anticipating the arrival of my magneto optical drive and disks. And perhaps I should look for a PCI SCSI card for my G4 so I can attach something like a Jaz to it.
I did find a few higher capacity MO drives that list backwards compatibility to 128MB disks. I’m thinking the better brands would be Fujitsu, Sony and Olympus. If anyone has an suggestions of particular drives and brands to look for and to avoid I would appreciate it. I find the medium intriguing.
Just to confirm, you tried Software Architect’s Disk Drive Tuneup 3.14 to format the disk?Hello everybody, I am fighting with a Sony SMO - F541 drive in an external SCSI enclosure: the drive is seen in the SCSI chain on my 7.1.1 IIfx (with the proper "black terminator"), but it seems to be unsupported: I tried all the software mentioned here in the thread to format some 2.6Gb disks with no result.
I ordered a new enclosure which is on its way, just to be sure, but I was wondering if meanwhile someone could share experiences with that drive.
Just to mention it, I have a couple SyQuests (44mb and 88mb) in external enclosures and they work flawlessly on the same machine.
7.1.1's HFS partition size limit is 2GB, so I wouldn't be entirely surprised if you're running into issues related to that. Do you have a newer Mac with SCSI (preferably PPC), to try it on a newer Mac OS version?I tried all the software mentioned here in the thread to format some 2.6Gb disks with no result.
these disks are double sided, so the max size is 1.3gb per side... it should be within limits, but I am installing 7.5 to give it a try anyway.7.1.1's HFS partition size limit is 2GB, so I wouldn't be entirely surprised if you're running into issues related to that. Do you have a newer Mac with SCSI (preferably PPC), to try it on a newer Mac OS version?
I will check the software version but I am quite sure I did and it said the drive is unsupported. I will let you know anyway.Just to confirm, you tried Software Architect’s Disk Drive Tuneup 3.14 to format the disk?
One set of switches will determine if the device is seen as an optical device, or not. The manual for the 541 and 551 should have the same dip switch settings.Meanwhile I took the drive out of the enclosure and I am noticing two sets of dip switches at the end of it... everything was set ON and I couldn't find a manual online - I found the f551 manual which has its own switch infos and I am thinking about trying to fiddle a bit with them, but I am not so sure this will bring me anywhere...
All switches should be in the "off" position (0, not 1).
Are you properly terminated ?After a more detailed check, here are the results with several formatters:
Fujitsu MO Formatter: says device cannot be handled
Pinnacle Formatter: does not recognize the device as removable MO
TuneUp v. 2.06 (with its extension installed): does recognize the device but waits for media even if the disk is inserted
TuneUp v. 3.14 (with extension installed) : freezes the Mac while scanning for devices.
I had a better look and cleaned up the switch block a bit, and they were indeed all OFF, even if the off position on these is up and not down as in the 551 manual... cleaning up I could see the ON mark on the other side of the switch block.
yes black terminator for IIfx is plugged to the second plug of the scsi box with the MO drive.Are you properly terminated ?
