Dynamac EL manual?
Having seen this strange beast in person, I was curious how the 640x400 video board works. Disassembling the "640 x 400" INIT from haplain's archive revealed a few tidbits:
Hardware
The DynaMac is based on a Plus logic board with stock ROMs. It appears that the VRAM for the DynaMac 640x400 display lives at $780000 in memory. That makes sense because it's an unused address space on the Plus.
There appears to be a control port at $7A0001, i.e. the low byte of address $7A0000. The Plus has a 16-bit bus but a lot of the peripherals use only 8 bits. Some of them are connected to the low byte of the bus while others are connected to the high byte. I don't know why that is, but anyway, it's the low byte (A0=1) here. Reading and writing bits to this address must query or set the status of the display somehow.
INIT
Most of the INIT seems concerned with a bunch of stuff relating to the cursor, which I didn't bother to pick through so I don't know exactly why it's there or what it does. But the interesting part starts at address offset $37C in the INIT resource. The approximate plan seems to be:
1. Check if the system ROM is what it expects. If not, exit.
2. Twiddle a series of bits on the control port at $7A0001  (this is the code starting at $398)
-- Set and test bit 3. If it reads low, exit.
-- Clear and test bit 1. If it reads low, exit.
-- Set bit 0, then read bit 2. If it reads high, exit.
3. Draw a grey checkerboard pattern in video memory at $780000.  (this is the code starting at $3F6)
4. Copy the video data from the old screen address (i.e. in Plus system RAM) to somewhere within $780000 -- I think with a row / column offset, but I'm not sure.
5. Update the QuickDraw variables to point ScrnBase (i.e. the screen memory address) to $780000 and update the size to 640x400.
6. Call some system trap stuff that I haven't worked out, but probably gets QuickDraw to sort itself out again.
I'm guessing that some part in Step 2 (twiddling control bits) must flip a switch to tell the DynaMac video hardware to display from its native VRAM rather than from the Plus video. Then it's just a matter of pointing QuickDraw to the new VRAM buffer and away you go.
