Color Classic color balance issues
jdlanza
Color Classic on the left has a purplish hue (CC on the right shown for reference purposes). Also, not sure if related, but the Brightness slider in the Screen control panel appears to have no effect on the display.
Anyone fixed this before? Is it a cap issue or something else?
Thanks in advance!
johnl
Often, but not always, a physical connection issue between either the logic board and the wiring harness or the analog board and the wiring harness. Remove both boards and spray contact cleaner on the edge connectors and retry. Make sure the boards are firmly/tightly seated.
Thanks, @joshc. I’ll give that a try and report.
