First of all, I'm new to the forum but have been reading and soaking up as much information as I can for the past few weeks. Wow, what a wealth of knowledge here. I love this place!
I have an SE/30 that I'm trying to resurrect. I've had this machine since I was a kid. It used to work, then sat after I went to college. A few years after I graduated, I took it out and powered it up again; simasimac. I attempted to recap it at that time, but my soldering equipment and skills were both garbage. My memory is a little hazy, but the recap didn't help, and I suspect I made it worse. I got discouraged and put it in a closet. 10 years later, I realized that I have the skills and equipment to fix it properly now. Its current symptoms are no bong, no video. Here's what I've done so far:
My only theory at this point is that maybe there was an internal layer connection at the + side of C11 that is still broken. Would testing voltages at the floppy connector help rule that in/out? The schematic is helpful but I don't have a good idea of what the 5V plane looks like. Any other theories would be very much appreciated. Thanks!
- Removed RAM, ROM, socketed PALs and video ROM, all electrolytic caps, UA8-UG8, UB12, UC12, RP2 and RP3
- Cleaned the board with ammonia and a toothbrush, rinsed with distilled water, then cleaned again with 91% isopropyl and baked at 170F for 30 mins
- Scraped back damaged solder mask from traces around C3-C6, UB10-UB12, UC12-UE12, RP2 and RP3
- Tinned exposed copper, verified continuity, repaired a broken trace under RP3, then removed flux and covered all trace repairs with green overcoat pen
- Replaced all radial electrolytic caps with new 25V-50V tantalums
- Replaced UA8-UG8, UB12, and UC12 with new parts. Repaired one torn off pad at UC12
- Cleaned, tested, and reinstalled the RP2 and RP3 filters
- Replaced axial caps with new higher rated parts
- Fixed a cracked solder joint on Y3
- Added a bodge wire from the + side of C11 to pin 13 on the J12 power & video connector. Apparently I damaged this via during my first recap attempt
- Reflowed all pins on J12
- Wiped RAM, ROM, PAL, and video ROM pins with deoxit D5 before reinstalling
- 3D printed potatofi's ROM clips and used them securely install the ROM in the socket since it has one broken clip
