MacAsm MiniMorse Masochism
Snial
68000
Earlier this year I became interested in learning the basics of Morse code. I had a very simple concept for my Morse code tutor, it would simply convert a letter I typed in into Morse or convert dots and dashes typed in, into a single letter. And initially that was because I wanted to fit it on a 1K ZX81 in BASIC, but then decided to write a ZX Spectrum version and also, then thought that would be a good, little project to write in Think C (and Think Pascal) for the Mac.
The program itself is remarkably effective at teaching morse code. All you basically need to do is start typing some real text, and it'll display the morse for it. Then as soon as you're familiar enough with the Morse for a given letter, type the Morse and see the letter instead. It took me about 15 minutes to learn pretty much all the alphabet + digits and another 10 minutes to become familiar with the unusual letters (because if you're typing normal text, they don't occur often enough to learn them).
And because the program is so simple, I thought I'd write a Mac version in assembler, using the very first Mac assembler: MacASM. I think I downloaded it from MacGUI (thank you) but it might have been Macintosh Garden.
MacASM is amazingly primitive, and consequently, very tiny, at 23916 Bytes, but it can handle 68000 assembler; macros for making traps calls easier; linking; editing and includes a resource compiler. It comes with the trap library as .inc files, Frankly I think that's amazing! MacASM really does make it possible to develop applications on an original 128kB Mac, though I can't say it's particularly suited to complex apps, for that I guess you'd need MDS.
Nevertheless, it works! Well, here's the code itself. I did all the development on a System 3 disk (which I think is an HFS disk; and is about 3MB in size. Here though I've converted it to run from a 400kB System 1.x disk image. After the listing I'll show you how to compile it and in future posts on this I'll bore you to tears with some of the details on MacASM development :) !
Code:
00010 ;SAVE "MiniMorse.asm"
00020 optDebugOn equ 0
00030 BrkPtTrap MACRO
00040   DO optDebugOn
00050   trap #1
00060   ENDM
00070   LIST OFF
00080   INCLUDE "ToolBox.inc"
00090   INCLUDE "Windows.inc"
00100   INCLUDE "Event.inc"
00110   LIST OFF
00120   GLOBAL 32,$200
00130   DEFV L,gWin
00140   DEFV Event.Sizeof,gMyEvent
00150   ENDG
00160   TFILE "MakeApp.sh"
00170   RFILE "MiniMorse",APPL
00180   SEG 1,4
00190 Start
00200   DO optDebugOn
00210   bsr DbgInit
00220   FIN
00230   bsr Init
00240   moveq #0,d7 ;gDone in bit 0 (global flag).
00250   moveq #1,d5 ;morseTap=1.
00260   bra.s Start10
00270 Start05
00280   bsr DoEvent
00290 Start10
00300   btst #0,d7
00310   beq.s Start05
00320 DoQuit
00330   TBX ExitToShell
00340 kTrap1 equ $4e41
00350   DO optDebugOn
00360 DbgInit
00370   lea DbgWait(pc),a0
00380   move.l a0,$84 ;TRAP#1 vector.
00390   rts
00400 DbgWait
00410 * Stack: D0.l:SR:RetPC
00420   move.l d0,-(sp) ;we use d0.
00430   move.w #-1,d0
00440 DbgWait10
00450   tst.w d0
00460   bmi.s DbgWait10
00470   beq.s DbgWait99 ;just skip
00480   cmp.w #$100,d0
00490   bne.s DbgWait15
00500   lea DoQuit(pc),a0
00510   move.l a0,6(sp) ;return to ExitToShell
00520   bra.s DbgWait99
00530 DbgWait15
00540   sub.l #2,6(sp) ;make pc return to same place.
00550   move.l a0,-(sp) ;save a0, used for
00560   move.l 10(sp),a0 ;src/dst
00570 DbgWait20
00580   move.w 2(a0),(a0)
00590   addq.l #2,a0 ;next word.
00600   dbra d0,DbgWait20
00610   move.w #kTrap1,(a0)
00620   move.l (sp)+,a0 ;restore a0
00630 DbgWait99
00640   move.l (sp)+,d0
00650   rte ;done
00660   FIN
00670 DoMenuBarInit
00680   link a6,#-4 ;menu bar.
00690   clr.l -4(a6) ; set to nil.
00700   clr.l -(sp)
00710   move.w #kMenuIdApple,-(sp)
00720   TBX GetRMenu
00730   move.l (sp)+,-4(a6)
00740   move.l -4(a6),-(sp) ;menu.
00750   move.l #$44525652,-(sp) ;'DRVR'
00760   TBX AddResMenu
00770   move.l -4(a6),-(sp) ;menu.
00780   clr.w -(sp)
00790   TBX InsertMenu
00800   clr.l -(sp)
00810   move.w #kMenuIdFile,-(sp)
00820   TBX GetRMenu
00830   clr.w -(sp) ;menu^^ is on stack.
00840   TBX InsertMenu
00850   TBX DrawMenuBar
00860   unlk a6
00870   rts
00880 Init
00890   link a6,#-2 ;reserve space for FontNum
00900   pea -4(a5) ;&thePort
00910   TBX InitGraf
00920   TBX InitFonts
00930   TBX InitWindows
00940   TBX InitMenus
00950   TBX TEInit
00960   clr.l -(sp) ;InitDialogs(nil)
00970   TBX InitDialogs
00980   TBX InitCursor
00990   move.l #everyEvent,d0
01000   OST FlushEvents
01010   SUBQ #4,SP
01020   MOVE #400,-(SP)
01030   CLR.L -(SP)
01040   MOVE.L #-1,-(SP)
01050   TBX GetNewWindow
01060   MOVE.L (SP)+,gWin(A5)
01070   MOVE.L gWin(A5),-(SP)
01080   TBX SetPort
01090   pea kMonaco(PC)
01100   pea -2(a6) ;&FontNum
01110   TBX GetFNum ;result in (a6).w.
01120   move.w -2(a6),-(sp) ;*&FontNum.
01130   TBX TextFont
01140   move.w #9,-(sp) ;size 9
01150   TBX TextSize
01160   move.l gWin(a5),-(sp)
01170   TBX ShowWindow
01180   bsr DoMenuBarInit
01190   bsr MoveOxOy
01200   LEA kHello(PC),A0
01210   MOVE.L A0,-(SP)
01220   TBX DrawString
01230   unlk a6
01240   rts
01250 MoveOxOy
01260   MOVE.W #10,-(SP) ;OriginX
01270   MOVE.W #10,-(SP) ;OriginY
01280   TBX MoveTo
01290   rts
01300 kMenuIdApple equ 128
01310 kMenuAbout equ 1
01320 kMenuIdFile equ 129
01330 kMenuQuit equ 1
01340 DoMenuApple
01350 kMenuAppleAccName equ -34
01360 kMenuAppleAccId equ kMenuAppleAccName-2
01370 kMenuAppleItemNum equ kMenuAppleAccId-2
01380 kMenuAppleHandle equ kMenuAppleItemNum-4
01390 kMenuAppleLocals equ kMenuAppleHandle
01400   link a6,#kMenuAppleLocals
01410 * d0.w=item.
01420   cmp.w #kMenuAbout,d0
01430   bne.s DoMenuApple10
01440   clr.w -(sp) ;dummy result.
01450   move.w #128,-(sp) ;kAboutAlertId.
01460   clr.l -(sp) ;push nil.
01470   TBX NoteAlert
01480   addq.l #2,sp ;discard result.
01490   bra.s DoMenuApple99
01500 DoMenuApple10
01510   move.w d0,d4 ;temp
01520   clr.l -(sp) ;Result (appleMenu)
01530   move.w #kMenuIdApple,-(sp)
01540   TBX GetMHandle
01550   move.w d4,-(sp) ;aItem.
01560   pea kMenuAppleAccName(a6)
01570   TBX GetItem
01580   clr.w -(sp)
01590   pea kMenuAppleAccName(a6)
01600   TBX OpenDeskAcc
01610   addq.l #2,sp ;discard result.
01620 DoMenuApple99
01630   unlk a6
01640   rts
01650 DoMenuChoice
01660   tst.l d0
01670   beq.s DoMenuChoice99
01680   swap d0 ;menu
01690   cmp.w #kMenuIdApple,d0
01700   bne.s DoMenuChoice10
01710 * Handle Apple Menu.. tbd.
01720   swap d0
01730   bsr DoMenuApple
01740   bra.s DoMenuChoice98
01750 DoMenuChoice10
01760   cmp.w #kMenuIdFile,d0
01770   bne.s DoMenuChoice99 ;no other menus.
01780   swap d0
01790   cmp.w #kMenuQuit,d0
01800   bne.s DoMenuChoice99 ;no other items.
01810   bset #0,d7;gDone=true
01820 DoMenuChoice98
01830   clr.w -(sp)
01840   TBX HiliteMenu
01850 DoMenuChoice99
01860   rts
01870 UiMouseDown
01880 kWhichWindow equ -4
01890   link a6,#kWhichWindow
01900   subq.l #2,sp ;push short
01910   move.l gMyEvent+Event.where(a5),-(sp)
01920   pea kWhichWindow(a6)
01930   TBX FindWindow
01940   move.w (sp)+,d0 ;
01950   cmp.w #inSysWindow,d0
01960   bne.s UiMouseDown10
01970   pea gMyEvent(a5),-(sp)
01980   move.l kWhichWindow(a6),-(sp)
01990   TBX SystemClick
02000   bra.s UiMouseDown99
02010 UiMouseDown10
02020   cmp.w #inDrag,d0
02030   bne.s UiMouseDown20
02040   move.l kWhichWindow(a6),-(sp)
02050   move.l gMyEvent+Event.where(a5),-(sp)
02060   move.l (a5),a0 ;a0^qd globals
02070   pea -116(a0) ;should be screenbits.bounds.
02080   TBX DragWindow
02090   bra.s UiMouseDown99
02100 UiMouseDown20
02110 UiMouseDown80
02120   cmp.w #inGoAway,d0
02130   bne.s UiMouseDown30
02140   bset #0,d7;gDone=true
02150   bra.s UiMouseDown99
02160 UiMouseDown30
02170   clr.l -(sp) ;reserve 4 bytes for where.
02180   move.l gMyEvent+Event.where(a5),-(sp)
02190   TBX MenuSelect
02200   move.l (sp)+,d0
02210   bsr DoMenuChoice
02220 UiMouseDown99
02230   unlk a6
02240   rts
02250 MorsePut
02260 * Disp each bit in turn as ./- until d6=1.
02270   move.b d0,d6 ;save in d6.
02280 MorsePut10
02290   lsr.b #1,d6 ;div 2.
02300   moveq #0,d0
02310   roxl.b #1,d0 ;
02320   move.b kMorseSyms(pc,d0.w),d0
02330   move.w d0,-(sp); push char.
02340   TBX DrawChar ;display the char.
02350   cmp.b #1,d6
02360   bgt.s MorsePut10
02370   rts
02380 kMorseSyms
02390   DATA #'.', #'-'
02400 Repaint
02410 * d0.b contains the ascii char, d5=morsecode.
02420   link a6,#-4
02430   and.w #$ff,d0
02440   move.w d0,-(sp) ;save char on stack.
02450   pea -4(a6) ;push VAR oldPort.
02460   TBX GetPort
02470   move.l gWin(a5),-(sp) ;push gWin
02480   TBX SetPort
02490   move.l gWin(a5),a0 ;gWin^
02500 ;offset to portRect is 2+14 = 16.
02510   pea 16(a0) ;portRect address
02520   TBX EraseRect
02530   bsr MoveOxOy
02540   TBX DrawChar ;it was on the stack.
02550   move.w #' ',-(sp)
02560   TBX DrawChar
02570   move.b d5,d0 ;MorseCode
02580   bsr MorsePut
02590   move.l -4(a6),-(sp) ; push oldPort
02600   TBX SetPort
02610   unlk a6
02620   rts
02630 DoUpdate
02640 * Event.message is the window pointer to update.
02650   move.l gMyEvent+Event.message(a5),d4 ;the window.
02660   move.l d4,-(sp) ;push the window.
02670   TBX BeginUpdate
02680   cmp.w gWin(a5),d4
02690   bne.s DoUpdate10
02700   bsr Repaint
02710 DoUpdate10
02720   move.l d4,-(sp)
02730   TBX EndUpdate
02740   rts
02750 kTapMax equ 15
02760 DoKey
02770   move.b gMyEvent+Event.message+3(a5),d0
02780   and.w #$ff,d0
02790   cmp.b #'-',d0
02800   beq.s DoKey03
02810   cmp.b #'.',d0
02820   bne.s DoKey08
02830 DoKey03
02840 * Morse Tap Support
02850   swap d5 ;timeout
02860   move.w gMyEvent+Event.when+2(a5),d5
02870   add.w #kTapMax,d5
02880   swap d5
02890   add.w d5,d5
02900   cmp.b #'-',d0
02910   bne.s DoKey99 ;done
02920   addq.w #1,d5
02930   bra.s DoKey99 ;done.
02940 DoKey08
02950   DO optDebugOn
02960   cmp.b #',',d0
02970   bne.s DoKey09
02980   move.w gMyEvent+Event.when+2(a5),d1
02990   trap #1
03000   FIN
03010 DoKey09
03020 DoChToMorse
03030   cmp.b #65,d0
03040   blt.s DoKey10 ;could be digit though
03050   cmp.b #65+26,d0
03060   bge.s DoKey99 ;out of range
03070   move.w d0,d5
03080   and.w #$1f,d5
03090   move.b kAlphaToMorse-1(pc,d5.w),d5
03100   bra.s DoKey20 ;done.
03110 DoKey10
03120   cmp.b #48,d0
03130   blt.s DoKey99
03140   cmp.b #48+10,d0
03150   bge.s DoKey99 ;also out of range
03160   ext.w d0 ;bit 7 of d0==0, so this clears upper byte.
03170   move.b kDigitToMorse-48(pc,d0.w),d5
03180 DoKey20
03190   bsr Repaint
03200   move.w #1,d5 ;reset morse code.
03210 DoKey99
03220   rts
03230 kAlphaToMorse
03240   DATA #6, #17, #21, #9, #2, #20, #11, #16
03250   DATA #4, #30, #13, #18, #7, #5, #15, #22
03260   DATA #27, #10, #8, #3, #12, #24, #14, #25
03270   DATA #29, #19
03280 kDigitToMorse
03290   DATA #63, #62, #60, #56, #48
03300   DATA #32, #33, #35, #39, #47
03310 DoNull
03320   cmp.b #1,d5 ;morseTap
03330   ble.s DoNull99 ;not started a MorseTap.
03340   swap d5 ;upper word =timeout.
03350   cmp.w gMyEvent+Event.when+2(a5),d5
03360   bmi.s DoNull10  ;d5-event.wh n=to
03370   swap d5
03380   bra.s DoNull99
03390 DoNull10
03400   swap d5
03410   clr.l -(sp) ;
03420   TBX FrontWindow
03430   move.l (sp)+,d0
03440   cmp.l gWin(a5),d0
03450   bne.s DoNull99 ;wrong window.
03460   and.w #63,d5 ;actual code.
03470   move.b kFromMorse(pc,d5.w),d0
03480   bsr DoChToMorse
03490   moveq #1,d5
03500 DoNull99
03510   rts
03520 kFromMorse
03530   ASC "0.ETIANMSURWDKGOHVF.L.PJBXCYZQ3."
03540   ASC "54.3...24....:.16.5....:7...8.90"
03550 DoEvent
03560   TBX SystemTask
03570   clr.w -(sp) ;push dummy result
03580   move.w #everyEvent,-(sp) ;we want every event.
03590   pea gMyEvent(a5)
03600   TBX GetNextEvent ;result in (sp)+.
03610   move.w gMyEvent+Event.what(a5),d1 ;temp var.
03620   tst.w (sp)+
03630   beq.s DoEvent01 ;no posted event, means NULL
03640   tst.w d1 ;nullEvent==0.
03650   bne.s DoEvent02 ;try next type.
03660 DoEvent01
03670   bsr DoNull
03680   bra.s DoEvent99
03690 DoEvent02
03700   cmp.w #mouseDown,d1 ;mouse down?
03710   bne.s DoEvent10
03720   bsr UiMouseDown
03730 DoEvent10
03740   cmp.w #keyDown,d1 ;key?
03750   bne.s DoEvent20
03760   bsr DoKey
03770   bra.s DoEvent99
03780 DoEvent20
03790   cmp.w #updateEvt,d1 ;update?
03800   bne.s DoEvent99
03810   bsr DoUpdate
03820 DoEvent99
03830   rts
03840 kHello
03850   STR "Hello World!"
03860 kMonaco
03870   STR "monaco"
03880   ENDR
03890   SEG 0,32,VAR.LEN,$20
03900 SEG0
03910 SEG_1  JP Start,1
03920 END_1
03930 END0
03940   ENDR
03950   LIST OFF
03960   RSRC  WIND,400,4
03970   DATA  /40,/40,/94,/160  ;Bounds
03980   DATA  /0  ;Wind Def
03990   DATA  #1,#0  ;Visible
04000   DATA  #1,#0  ;GoAway
04010   DATA  0  ;refCon
04020   STR  "MiniMorse"  ;Title
04030   ENDR
04040 *--------------------------------
04050   RSRC  MENU,kMenuIdApple,4
04060   DATA  /kMenuIdApple ; Menu ID
04070   DATA  /0,/0
04080   DATA  /0  ; Menu Def.
04090   DATA  /0
04100   DATA  $FFFFFFFB  ; Enable Flags
04110   HEX  0114  ; Title (Apple logo)
04120   STR  "About..."
04130   DATA  #0,#0,#0,#0  ; Icon,Keyboard,Mark,Style
04140   STR  "-"
04150   DATA  #0,#0,#0,#0
04160   STR  ""
04170   ENDR
04180 *--------------------------------
04190   RSRC  MENU,kMenuIdFile,4
04200   DATA  /kMenuIdFile
04210   DATA  /0,/0
04220   DATA  /0
04230   DATA  /0
04240   DATA  $FFFFFFFF
04250   STR  "File"
04260   STR  "Quit"
04270   DATA  #0,#'Q,#0,#0
04280   STR  ""
04290   ENDR
04300 *--------------------------------
04310   RSRC  ALRT,128,4
04320   DATA  /100,/100,/188,/400  ;Bounds
04330   DATA  /128 ;DITL ID
04340   DATA /$5555
04350   ENDR
04360 *--------------------------------
04370   RSRC  DITL,128,4
04380   DATA  /2-1   ;Number of Items -1.
04390   DATA  0
04400   DATA  /10,/64,/42,/290
04410   DATA  #8 ;Static text.
04420   DATA #AboutMsgEnd-AboutMsgStart
04430 AboutMsgStart
04440   ASC  "MiniMorse "
04450   DATA #$A9 ;Copyright
04460   ASC "Julz 2023"
04470   DATA #13 ;CR
04480   ASC "Type A-Z,0-9 <=> .-.. (Morse)"
04490 AboutMsgEnd
04500   DATA  0    ;Handle or proc^ placeholder
04510   DATA  /60,/230,/80,/290  ;Disp Rect
04520   DATA  #4   ;Type=Button
04530   STR  "OK"   ;Content
04540   ENDR
04550   end
You'll the code in the main disk's window. The Libraries for the include files are in another Folder, but since this is a System 1.x disk image the folders are a fiction, it's really a flat disk format and the inc files can be included directly. Here's how to make it: Double-click on MiniMorse.asm and it'll open MacASM to edit it. Type: asm<cr> and MacASM will start to assemble the code. It would normally display the text it's assembling as it goes on, but LIST OFF turns that off to speed things up. Even so, it's pretty slow if you run miniVMac at 1x. Don't press any keys while it's assembling as it'll pause and won't tell you it's paused. Eventually it'll say:
0000 Errors In Assembly
Ok.
Type quit to exit MacASM. You'll see there's now a file called MakeApp.sh in the MinMorseFull window. Strangely, MacASM didn't link the file in the first pass, but double-clicking on MakeApp.sh will run MacASM again and automatically link the file producing the App: MiniMorse. Double-click that and you get the app:
Which greets you with "Hello World!" thanks to me leaving the even more humble origins of MiniMorse in the code. Typing in a capital letter or digit generates the appropriate Morse and quickly typing in a sequence of dots '.' and dashes '-' converts it to a letter.
MiniMorse has enough of a normal Macintosh application implemented to make it seem as least a little bit conventional. Considering that MiniMorse is only 1473 bytes long I'm pleased with that. You can move the window; it handles an About... box and desk accessories. The single File:Quit menu option is supported, but closing the box also does the same thing, returning to the desktop without crashing!. If something obscures the window and it has to redraw, it doesn't do it properly though. I've assembled and run MiniMorse on System 7.1 and System 1.x, 2.0, 2.1 (on an emulated Mac 128kB), and 3.0.
In future posts on this topic, I'll outline a bit about what it's like to work with MacASM and how I did some debugging with it. I might even get around to converting the manual from the massive 22.3MB of scanned images into the real, typewritten thing that looks like it was written on an Apple ][ ;) !
If you get around to playing with it, send me a simple Morse code message in a reply and I'll see if I can decode it ;) !
Nice work on the software! If your goal is to learn Morse for amateur radio use, however, most people recommend that you don't try to learn written lists of dashes and dots, or anything visual at all. It's not just less effective, it's actually counterproductive because it teaches mental habits that don't scale up well to real-time Morse usage at decent speeds, and must eventually be unlearned. Most teachers and tools suggest some variation of listening to Morse at a speed that's difficult for you but not impossible, and then write or speak aloud what you heard.
I spent quite a while learning Morse Code during summer 2022 and was eventually able to make a few dozen radio contacts using it. https://www.bigmessowires.com/2022/04/27/learn-morse-code-for-fun-and-profit/
"I didn't make this using minimorse. but you can try decoding it anyway! C"
Cool! OK, so I didn't decode your message with minimorse here, but learning morse with minimorse is the reason I was able to do it by hand! Took me a few mins though ;-) !
Ha! Maybe I have to upgrade MiniMorse to include audio ;-) ! It could get up to 2kB then ;-) . I get why it's likely that learning Morse symbolically rather than audibly can be counter-productive: different neural pathways (e.g. temporal vs spacial).
Amazing! I think my original motivation for learning morse was that a colleague at my place of work at the time knew Morse and is only in his early 20s (pretty new Graduate), but also because I watched the TV series 1899 (Netflix?) and there's a section in it where they use morse code - it's always the case in any sci-fi that when people are trapped someone knows Morse! I thought, it's about time.
Meanwhile here's a link to the ZX81 version. It works in real-time, like the Mac version (which I'm pleased with as the ZX81 is astoundingly slow).
-cheers from Julz
Yes, I should probably try to learn some morse myself (about all I know is SOS, so I can tell people if I'm in trouble, but not much else). Do you think MiniMorse would work under System 7.5.5 in MinivMac's MacII mode? I'll have to try it and see.
@bigmessowires Neat! I'm assuming you have an amateur radio license? I've been thinking off and on about getting one, but I don't really want to speak, and I'm not sure what it's good for other than communicating in emergencies or some such.
And besides, my main interest lies in playing music, which is explicitly forbidden over amateur radio, so, well....
c
Yes, I have an "extra" class amateur radio license. Initially I was super excited and was constantly using the radio, but I haven't used it so much lately.
You're in good company and there are several areas where no talking is involved, or where the only talking is a short exchange in a standardized format. Most people think of amateur radio as giant antennas used to call somebody in Tasmania and chat about the weather, which is fun but isn't everybody's cup of tea.
FT8 - This is a semi-automated digital mode for making and logging contacts with other radio operators. You run software that connects to your radio, listens on a frequency, and displays a list of radio stations that are broadcasting a "who's out there". Click on one to send a standard reply. If the radio conditions are good, the two sides will automatically exchange their call signs, locations, and signal strength reports. It's a good way to prove your radio setup and test the limits of radio signal propagation without needing to make small talk.
Digital networks, modems, Winlink - You can do email or file transfers over amateur radio, using a specialized modem. It can be point to point with another radio operator, or more typically as part of a mesh network.
Parks on the Air, Summits on the Air, various contests - These are examples where the goal is to contact as many radio operators as possible, and log them all, for some kind of contest or special event or fame points. Exchanges are spoken, but are very brief and follow a standard script so there's no chit-chat.
Download from the International Space Station - There are two amateur radio transmitters on the ISS (one Russian and one from USA) that broadcast a variety of stuff. Occasionally you can talk directly with an astronaut, if you get the timing right while ISS passes briefly over your location. You can also use repeaters on the ISS to talk with other radio operators far away who'd normally be out of range. More often the ISS is transmitting some digital data that you can downlink and decode. Here is an image that I downloaded directly from the ISS: https://www.bigmessowires.com/2022/04/12/international-space-station-downlink/
Download from Earth observation satellites - Similar to the ISS, you can connect and download images and other data from weather satellites and other observations satellites. There are also a few satellites that are specifically for amateur radio use.
Moon Bounce - With a directional transmitter and enough power, you can bounce your radio signal off the moon and send it back to a different location on Earth, enabling communication paths that wouldn't otherwise be possible. Even harder: you can also bounce signals off of meteor showers.
Morse code - There's obviously no speech involved here, although it does typically involve some conversation. Unless you are really great at Morse code, the conversations are pretty brief in my experience. Name, location, type of radio, transmit power, maybe a weather report, and that's about all.
VHF/UHF radios - These are the opposite of what you probably think of when you imagine amateur radio. They are small radios with small antennas, and may be hand held or installed in a car. The range is only 5-10 miles or so, but there are radio repeaters all over the world that will pick up and rebroadcast your signal, so the effective range is larger. In my experience this is the worst place for somebody who doesn't really want to talk. It tends to be full of windbags talking endlessly about antenna designs, complaining about the government and immigrants, and chastising other people for not following radio regulations.
Morse code trivia: the code that everybody uses today is not the one developed by Samuel Morse in 1838. That code was retroactively named American Morse Code, after the rest of the world adopted a different version. American Morse is rather strange, and is now more-or-less extinct. Everybody today uses International Morse Code.
