My Beige G3 tower started having problems recently, so I figured a re-cap was in order. I didn't find any guide or capacitor list so I decided to make my own for reference as I worked.
Here is a capacitor list for the board and the capacitors I used (I haven't done the tiny 10uf 16v yet because I need a smaller iron tip than my normal chisel tip). They're all a slightly smaller package than I've normally used on older systems because there are more small components around the ones on this board.
16 - 47uf 16v https://www.mouser.com/ProductDetail/581-TAJC476K016SNJ
5 - 100uf 6.3v https://www.mouser.com/ProductDetail/581-TAJC107K006R
1 - 10uf 16v https://www.mouser.com/ProductDetail/74-595D106X9016B2T
One of the 100uf 6.3v capacitors is on the personality card (the case on both my basic one and video in/out one), but double check to see if yours has it as well.
Additionally, the voltage regulator board has four tall through hole electrolytic capacitors:
4 - 1500uf 6.3v
I haven't done my voltage regulator yet, but I have polymer capacitors on order that should work and will update when I get them and test them.
4 - 1500uf 6.3v
