Weird Takky Color Classic Issue
Hi I have a strange issue with a Color Classic w a Takky mods. Basically it boots when I have it tipped forward but when it's set upright normally it's almost like the screen shorts out after a few seconds. The LED and the screen power up and then immediately shut off. It seems to be related to the whole unit (CRT, logic and analog) settling and shorting. The logic board was just recapped and that seemingly fixed a low power issue - but this startup issue remains unless the unit is leaning forward. Any ideas?
might be a broken trace or cracked solder joint on the analog board, try looking for it and fixing it, use a magnifying glass if you can't see it
How tight is the analog board sitting in its connector? Hit both ends with contact cleaner and reseat it a few times. Do the same with the logicboard. I’ve been repairing colour classics with @cheesestraws recently and the connectors have been the biggest causes of intermittent issues like this, after bad caps.
Agreed - before you go peering at solder joints with a magnifying glass, do yourself a favour and just clean the heck out of all the connectors in the wiring harness.
Quick Q - is this with the back bucket on, or off?
This is a good question, and I know what cheesestraws is getting at here.
Basically, the grounding points on the logicboard rely on the metal ground loops touching various points of the metal cage under the machine. Depending on how you are testing, if the bucket is removed and the machine standing upright, the metal cage may be touching bits of the logicboard it shouldn't.
It's worth checking that those ground loops are making good contact, but also that the metal shield is not shorting anything on the logicboard as well. All in all, it's a really fault prone design unfortunately.
A slight clarification - on the original logic boad. The little ground contact things in the shielding are in the wrong place for other boards, which is the problem, and the metal is bendy. So if you have it out of the back bucket, when you rest it on the shielding it's absolutely possible that it will just short bits of the logic board out, which probably isn't ideal.
Why, yes, @joshc and I lost a certain amount of time to this, and why, no, we're not bitter at all... :-p
Why, yes, @joshc and I lost a certain amount of time to this, and why, no, we're not bitter at all... :p
Indeed. This + the AB edge connector as well which is just as problematic as the logicboard one. And depending on what is or isn't working, it could be either of them, or both to blame. Fun times indeed.
Thanks all - lots to try here - I did wonder about the metal shielding under the analog board. I removed the shield under the LB. What's really the point of the shielding functionally?
I'm going to nail the connectors on both.
Scratch that the shielding is there - I do think it's related to these two shields under each boards given ifs propensity to fail when they'd be closest to them.
The shielding has two purposes in the CC - the first is to provide ground references to bits of the PCB. This was probably a bad idea.
The other, more important reason is to try to prevent RF emitted by the computer from screwing around with other electronics in the area, which may include your neighbours'. So it's best to leave it on - but I would suggest bending the little hook-shaped flaps away from the LB. When the back bucket is on, if the takky mod was done even remotely competently, the flat shielding will not short out the LB.
Hey, did you ever get this issue resolved?
I have two TAKKY Macs. I took them out of storage recently to fiddle with.
At first they were both running fine. But they randomly started having the same issue of sometimes powering on for a couple seconds then shutting off.
Both of them started doing this after I connected an external SCSI CD-ROM drive. Not sure if that's a pattern or a coincidence.
I haven't opened this up yet. But I was planning to replace the IDE drives with SSD IDE drives from OWC.
Any Takky is a complete hack job, therefore if you didn't do it yourself and take care, there is good chance the mod done years ago by someone else isn't up to scratch :( Ideally you need to tear it down and check wiring, recap the analog board and check the video/VGA mod was done properly.
As noted the edge connectors are highly sensitive this includes both the motherboard and analog board connectors.
Agree with @Byrd - there is no such thing as a "standard" Takky, so you're going to have to do some more digging yourself. Edge connectors are often an issue even in standard CCs though, and the PSU design is ... cost-optimised. So either of those two things might not be helping here.
