I was resurrecting an old Lombard last week that was missing a few bits... all went well but the heat was gone and I couldn't find a replacement down in the basement. I have a feeling there is one down there some where so I am loath to go to the bay and spend just yet. I cut a plate of mild steel, 3/16" by about 1.5" and 3" that fit in the 'pocket' above the processor and starter her up and she seems to run well enough. the temperature above the processor does not go over 98 deg. and at the top most edge tops out at about 112 deg. Fahrenheit (37c/45c) . It is odd to me that the plate is hotter at the top as it is not touching anything.
Can anyone tell me if those are reasonable working parameters for the Lombard processor?
