I feel like this has been probably been discussed extensively, but, I haven't quite found the info I am looking for. I am eventually going to build everything into a 9600 (well, a 9500 in an 8600 case), but for now the test machine is a 7300. Here are the specs:
RAM : 320MB
CPU : G4 @ 470MHz or G3 @ 520MHz
Boot device : hoping eventually a Rabbit Hole Computing SATA Hard Card
currently a ZuluSCSI (SD card)
GPU : ATI Rage 128 16MB
I installed OS 9.1, but it just didn't seem to run right. There seemed to be a lot of lag; it seemed periodic to me but I can't say for sure. From what research I have done, I thought 9.1 would run perfectly fine on this setup. Is it possible my install was corrupt?
8.6 ran great, no complaints. I currently have 9.0.4 installed, and that seems somewhat buggy too. It overall runs OK, but one thing I noticed is when I open a folder and try to scroll down, it keeps resetting to the top of the folder. It does this for like 10 seconds.
I have heard a lot of people prefer 8.6 over newer versions, since it runs better and is less buggy. But I have also heard that if I have plenty of RAM, I should choose 9.1 or newer. So my question is, with a setup like mine with relatively plenty of RAM and CPU, which version should I choose? Should I try and get 9.1 running right, or even 9.2.2? Or should I run 8.6, and just pull whatever drivers I may need from newer versions to get things like USB working well? I know this is a subjective question, so definitely just looking for opinions. I highly value speed, efficiency, and less bugs. However, I do want to get SATA and USB working.
RAM : 320MB
