Windows HFS Read-Write in 2023?
Hi all. Looking for solutions to write to an HFS (not HFS+) volume, only have Windows 10/11 machines available. My idea was to take an SD card, format it on Windoze, copy over .sit/.cpt/etc files using Windows Explorer, putting the SD card in a SD-PCMCIA device, and put the PCMCIA card in PowerBook 3400cs. I tried to pick some wisdom from https://68kmla.org/bb/index.php?threads/how-to-install-software-on-macintosh-plus.43764/#post-477949 and https://www.hawkdive.com/get-full-read-and-write-access-to-hfs-formatted-drive-on-windows/ but not quite seeing how to do HFS for System 7.x
All ideas appreciated, thanks!
Why can't you dual boot into a Linux installation? Or maybe this (install msys2 or ming first)?
I do have Windows Subsystem for Linux installed. However, my config is setup for Intellivision development at the moment and I don't have enough skills to do multi-boot. In my case, the Linux journey adds a lot of overhead for a low-end operation like read and write. In addition, that project is for HFS+ which isn't compatible with my 6.0.8 and 7.x systems. Thanks for the idea, though!
You can edit one of my drive files using Basilisk 2 so it contains whatever files you want. Then raw write the file to your SD card for use with your PCMCIA card. Or you could make a binary image of your 3400cs's IDE drive using a usb to IDE adapter. Then edit that image in Basilisk 2, then write it back to your drive
HFVExplorer is an old program, but it still works fine on my Windows 10 PC. It will write to an HFS disk image (which you can also mount/edit with Mini vMac, Basilisk II, or Sheepshaver). Then use a tool like Win32DiskImager to write the disk image to your SD card.
But I'm not sure if the SD Card when it's mounted in your PCMCIA adapter will expect to have a partition map like a hard disk. If so, this probably won't work.
Will the PowerBook read a FAT32-formatted SD card? If so, then you don't even need to reformat it as long as you're sticking to sit, cpt, and other archives without a resource fork.
Hmm, yes I realised I linked to an HFS+ subsystem. I've been using HFSUtils (which is HFS) on my Raspberry PI for similar purposes. Another way might be to run some virtual images using InfiniteMac.org:
You can get blank HFS images from here:
If WSL / WSL2 supports the dd command, then you should be able to create a blank image and then dd it to the device:
dd of=/dev/whateverTheCfCardIs if=myHfsImg
With a large CF card, >2GB, you'll have to create multiple partitions. I wrote a utility in 'C' to do that for a disk image, called APM tool:
The rationale is that, like FAT16 disks, only 64k clusters (blocks) are allowed, so for large disks, even the smallest files take up 32kB or so. I split my 8GB SD disk into several smaller partitions, or rather what I did was to create a 750MB disk image and clone a number of partitions, which is possible because as standard an HFS disk already pre-allocates about 16 partitions.
