Which is the better PM 9600 mainboard?
CD5150
I will be picking up a Power Macintosh 9600 later this week and would like to know the differences between a "Tsunami" and "Kansas" mainboard. Wasn't "Tsunami" the codename for the PM 9500 and any clone that was based off it? Overall which one would be better?
Congratulations - post about the config :) interesting to see what CPU, and PCI cards it has!
Yeah, there is very little difference between the 9500 and 9600. Basically the Tsunami 9600 boards are just a 9500 board with a different power connector.
Not really much difference.
Tsunami Pros
Works with BeOS
Kansas Pros
Slightly better G3 / G4 upgrade compatibility due to cache on CPU card Works with 250MHz+ Apple 604ev Processors
I think the later version of the 8600 ROM that fixed G3 upgrade issues won't run anything before OS 7.6.1.
I think you mean 9600 which has 6 PCI Slots. The 8600 has 3 PCI Slots even though it uses a similar if not identical case to the 9600.
What did they change in the ROM and when? I haven't heard of this.
Both of my 9600s (tsunami and kansas) happily boot 7.5.5 and even 7.5.3 even though it isn't officially supported. Preventing 7.5.5 (what I understood to be the Apple quoted minimum OS) from trying to boot a 9600 would have needed a new machine gestalt. The 9500 and 9600 all have the same gestalt, which is why 7.5.3 boots a 9600 - it thinks it is just a 9500 (which it basically is).
Edit
Ah, I think I know what it is. Apple often quote the OS a machine shipped with as the "Minimum" and this is what thevApple site and everymac say. It sometimes isn't true, for example here.
The 9600/200 was a 604e-based machine more or less the same as the 9500 — only a later iteration, and thus modestly improved over the 9500. I think, for instance, that its cache was expandable, and that you’d be far likelier to get a 233mhz 604e card (rare) running stably in it than you would in an early 9500.
A Kansas machine ran a 604ev processor at 250, 300 or 350mhz, as I recall. The 604ev was smaller than the 604e, was cooler-running, and had an integrated 1mb cache, among its refinements.
One advantage of the 9600/200, however, is that it allows experimentation with dual processor 604e cards. No workie in a Kansas board, so far as I know.
I’d jump at a 9600/200.
I struck purple! G3/300 with 512k of cache! It's effectively the Power Express 9700 that we never got. Best $125 I have ever spent. And yes, it works. PRAM battery was also replaced. It had 272MB of RAM (4 x 64MB + 2 x 8MB) but sadly 2 of the 64MB modules are causing the system to be unstable. It also has the stock floppy and CD-ROM drives. 12x maybe? Had Mac OS 9.1 installed on a 4GB SCSI HDD and there is another 9GB SCSI drive as well. I wiped to slate clean and reinstalled 9.1 on the 4GB drive as there were personal files on it. It's yellowed a bit. Is retro brite an option?
Personally I let them be. I've heard it makes the plastic go more brittle and the yellow comes back quicker.
At 25 years old, they're allowed a little colour change. My beard's been greying for years.
S
Silly question time... So is that a virtualised PowerPC or still emulated? So just emulating a PPC on a PPC?
Virtualised I believe, but wouldn't say with confidence. While not looking great on screen with the tests it has done so far, I think it scored fairly well overall. Well into the beige PPCs.
