Hello all,
I acquired a recapped SE/30 about a year ago. All was well until early this year when the notorious Quantum hard disk failed.
The machine shipped with System 6.0.8 and before this failure I had already purchased a USB floppy drive and floppies to create install disks (using a TiBook with Tiger so I can format and write images / files with Mac OS Standard formatting). I successfully upgraded to System 7.0.1; shortly after this, the drive failed.
Once this happened, I bought a RaizinMonster (CF to SCSI adapter) from artmix and a 4 GB SanDisk Extreme CF card. My dilemma is that the SE/30 will not recognize the CF card (using a boot disk and a patched copy of HD SC Setup 7.3.5). I downloaded Lido 7 onto the TiBook but the application is too large to fit onto my System 7 boot disk.
Is it possible to create a barebones boot disk that has room for Lido?
Also, what is the reason why HD SC Setup won't recognize the RaizinMonster/CF card as a SCSI device (I removed all the jumper pegs for ID=0 and Termination=ON for internal use)? Is an AztecMonster instead the way to go / is there any preliminary formatting I have to run the CF card through in order to use with Apple's utility?
A lot of questions I know, but I miss using this machine. I even found an ImageWriter II to use with it for old-school word processing.
Any help with this is much appreciated.
