Yeah I just don't usually bother replacing PRAM batteries unless I have a real good reason. And there really isn't any, unless you have working main batteries. The only one of mine i'm planning on replacing with a new one is my 3400c, and only because I have 5 working battery packs for it so it will charge and you can't swap out battery packs without needing to jump-start off the charger unless the PRAM battery is installed and working. You can warm-boot off a battery just fine without one, but cold booting after it's lost all power requires the charger unless the PRAM battery is installed.
