Oh that may be hard to find for me. I bought mine after the previous owner recapped its boards. I should be able to get all of the rest at least.
I’m working on it but it may take me a little while so I’ll follow up in a bit.Don’t worry about it. I can find the values online elsewhere. Thanks for the LB photo.
If you have a replacement lcd for the powerbook duo is it possible to seal it yourself to prevent moisture from getting into it
