Anyone got a spare Beige G3 ROM?
I’m planning on polymer myself. More authentic looking.
Yeah I just picked up another g3 all in one.. this one is not working 100%. Not sure if psu is bad, or flyback. I get no chime with another working board, and get this funky screen with flashing question mark.
This is probably a stupid question, but is there any difference between the rev B and C logic boards, or is it just the ROM chip? In other words, could I put a Rev B or C ROM in my pessimum Rev A beige minitower?
Yeah. Back in around 2000 I upgraded my (or should I say my family’s) Rev A G3 minitower with a Rev B ROM so I could get slave IDE support.
I actually discovered that the Rev B ROM is the best one, because the Rev C is incompatible with the Sonnet Tango Trio (or similar flashed combo cards). I wonder what they changed in Rev C other than breaking something.
Just to muddy the water, one of my Beige G3s has a 4-chip Rev A ROM.
index.php
Some of OWC's Rev A variants are just different manufacturing dates?! Or am I missing something. Not that it really matters, I think they're got a bit caught up in board revisions over ROM contents. Although perhaps it helps with identifying.
My three G3 ROMs (unfortunately I covered the chip versions without thinking when I made them easy for me to identify :s ):
Are you sure that's a Rev. C. From the chip number, I'm thinking it might be a Rev. B instead of Rev. C. The ROM Revision in Apple System Profiler is different. Trails "F2" vs. "F5", IIRC.
I based my labels on System Profiler. The machine is not set up at the moment.
Yes, there were reports way back when that the Rev. C broke compatibility with some obscure brand of Wifi card, or something like that. REallly old memory. I don't recall hearing it caused problems with Tango Trio, but it is not surprising. Apple, of course, never disclosed how a C was better than a B. As long as it was incompatibilty with a card I would never see in the wild, C still seemed good to me. This report of Tango Trio problems is more disturbing.
AFAIK, all Beige G3 ROMs work in all Beige G3 motherboards. I've never heard of a failing combination.
Interesting. Thank you.
I have a 2-chip Rev. C with Apple part numbers and several 2-chip Rev. As all with the same (as each other) Apple part numbers on the chips, but the only Rev. B I've ever had was actually a Flash module with multiple chips, so I've never gotten teh chip numbers for the Rev. B. Still pretty sure that the 'c' should be 494, 495 and I'm seeing 488 (438?) on your Rev. C module.
Please, I'm pretty sure that is a Rev C. It's easy to ask, but I'm not searching through my 5 Beige G3s to find my one Rev C ROM that I have already carefully worked out which Rev it is and labelled so I don't have to check which Rev it is!
No problem. It' s just new information to add to the pot.
This is directly from Sonnet’s tech spec document:
“Some Beige Power Macintosh G3 Minitower and Desktop machines (those with a revision 3 logic board) are incompatible with the Tempo Trio. To determine your computer’s logic board revision, open the Apple system profiler utility and find the ROM revision line. If the information listed is $77D.45F2, your computer has a revision 3 logic board and is not compatible with the Tempo Trio.”
The statement is not totally accurate. There is no such thing as a revision 3 logic board, they mean the ROM.
Will see if I can fire up a G3DT or MT to confirm.
Well... that took W A Y longer than planned! :rolleyes:
However, I can now confirm that the ROM I posted a pic of is indeed a Rev.A. Bummer. I did, however, pull the ROMs from all my beige G3s and can add the following info to the database... Firstly, a "WRAITH ROM" from one of my G3 MTs :
Going by what I could find on the interweb, concensus seems to point to these being Rev.A or Rev.B. Mine, however, is a Rev.C. Go figure.
Next I went through my other 4 ROMs...
Anyone want to take a chance on calling these?? :) Hint - spot the differences.
