I'm looking at this old 16mhz 68000 accelerator for an SE, and I can't quite figure out what's going on with the PDS connector. I know this style of male PDS connector with just exposed pins and no plastic surround was seen on other boards as well. What I can't figure out is why it appears the pins aren't soldered to the board. In the photo of the full back of the board, you can see many of the pins are bent, it looks like someone removed the card at an angle by pulling up on the far edge. I asked the seller about the bent pins, and they attempted to straighten them, which is why they look different in the close-up photos. I asked if the connector was loose, thinking maybe someone had removed the PDS connector at some point and just set it back in, and they said nothing is loose. I also can't tell if the pins are rusty, or if they just appear that way in the photo. No other part of the board looks corroded to me.
Does anyone have any thoughts about the seemingly un-soldered pins, or the condition of the connector?
