MacPython 1.5.2 for 68k machines - no numpy?
I just installed MacPython 1.5.2 from the Macintosh Garden. Wow! I didn't think Python was available for the 68k machines.
I saw that numpy is included with the installer but only for PPC machines. Was there ever a 68k version of numpy?
Thanks!
Supposedly the Easy Install mentions installing NumPy 11.
When I select a Custom Installation then I see NumPy is for PPC machines.
I install all the 68k options and then run compileall.py and it bonks out when it tries to compile Numerical. The libary does not exist in the Lib folder.
I also noticed the Tkinter packages are in subfolders, as if they should be treated separately? Am I missing something?
That said, it's probably not generally taken as a compliment, yes?
c
It's a fairly tame insult, usually used when someone you care about has made an avoidable mistake or to describe a harmless / bumbling fool. You'd get away with calling your partner it if they forgot their sandwiches or something.
