I turned on my Centris 650 after cleaning it up and it seems to work! A chime rang out and the monitor lit up!
Unfortunately, it won't boot.
The screen shows a floppy disk with a flashing question mark.
Did I destroy the drive? Did I destroy the built-in SCSI controller?
Is there a way I could make a boot floppy on my Windows machine to see if the Centris is toast?
Edit : I think the keyboard is dies after power-on. Pressing Caps Lock and Num Lock does not illuminate the LEDs on the keyboard.
Thanks!
Thanks!
