Well, had a powerbook 100 that worked when I brought it home. Next power on, infamous black back lit screen. cleaned and recapped it, nothing, no change.. last one of these i buy.. two useless laptops.. anyone need a nice display or two??
So that’s why! I assumed it had just spread the flux I used all over the place instead of picking it up but I guess not. Wonder why that is. What specifically do you mean with the inverter board? Brightness or contrast?The mainboard uses that painful varnish that becomes sticky when cleaned with IPA
That makes some sense, and since Sony (which at the time was primarily into manufacturing A/V equipment, I think) manufactured the 100 for Apple under contact, it follows that the 100 might have some odd design decisions that are unlike virtually every other PB, such as, for example, the use of (possibly of the logarithmic, audio type*) rotary pots for brightness/contrast instead of the (presumably linear) sliders found on all other members of the 1xx family (save for the 190/5300, which used push buttons).Well most of the potentiometers are linear nowadays
In the 80s as they were mostly used for (audio) volume, a lot of them were of the "log" type
I’ve 3D-printed replacement bumpers for the hard drives - really just round spacers the arm rests against. I presume you have the Quantum GoDrive. I’ve replaced four of them now, two for my Compaq Contura Aeros as wellThe harddisk has sticky heads, replacing it with an SD costs more than the price of the PB100 itself
The inverter never works "as new" even when recapped (the brightness range is wrong).
Yes it's a matter of personal taste, the hobby allows to restore "in your own way" in many areas
I always replace hard disks because I consider they are timebombs, much more so than the rest of the electronics. They are also eating a lot of power which puts strain on the rest of the machine and external psu (even more so if you replace the battery like I did on one of my PB100)
However I always keep them so that they stay with their original machine. This can be reversed.
