The FW/USB/SATA cards that work in this application are probably a better solution. But the Trio is neat. Found mine on Buyee.jp in case you use that site.That's amazing I'm so jealous of your trio, I've been hunting for one of those for ages.
Yeah I have some of those I’ve just always wanted a trio neat bit of history that one. This whole thread is amazing though. I’ve yet to try out the latest hack here but I’m super excited to try it when I unbury those systems again.The FW/USB/SATA cards that work in this application are probably a better solution. But the Trio is neat. Found mine on Buyee.jp in case you use that site.
This is all very cool to see developing. One thing I'm curious about is whether or not this sort of patching could be applied to the ROM of the SuperMac S900 ("Storm Surge"?). As far as I know, the issue faced by the S900 is that four of its six PCI slots are behind a PCI-PCI bridge and because of this the ROM does not identify many installed cards correctly. PCI cards that themselves have PCI-PCI bridges do not work at all, AFAIK. Are these similar issues or am I barking up the wrong tree?
The solution at #232 doesn't explain the real problem. It's a workaround which postpones the problem by probing the ATI fcode last after all the other PCI slots/bridges are handled.Are the issues with the S900 at all related or similar to the Gazelle's issues?
What???The FW/USB/SATA cards that work in this application are probably a better solution.
What???Got a list of those cards to look out for? Just USB/SATA trumps Trio in my book.
The only FW device I have is a Zip Drive. If there's not a FW interfaced NIC -> fast Ethernet available, I can't think of much use for it these days given SATA? If there's none available, such might make a really neat project?
68kmla.org
I’d like to make it compatible with other machines, so height would have to remain standard. Another idea I had was to make a custom riser for the TAM specifically with a device or two on it.For the TAM you can make the card taller than standard PCI, at least up until it might conflict with the G3 card.
edit: If you can constrain it to fit within the space of the CSII NIC, I've got a project here somewhere around here where I developed the spec for a TwinSlot PCI riser to allow for a great VidCard to be installed in the primary slot and second PCI card in the NIC/Riser combo cubic. Besides, isn't a USB NIC a bit faster than the available CSII NIC? I've got a cardboard/connector prototype, but not up to board design/fab at this point in my quest.
What about a small daughter card that would probably not really add to the thickness but give you more PCB real estate. Seems an appropropriate solution given the vintage nature of our stuff as well, lots of our old cards did it that way to get extra room.I’d like to make it compatible with other machines, so height would have to remain standard. Another idea I had was to make a custom riser for the TAM specifically with a device or two on it.
Hey @Trash80toHP_Mini, it's probably worth catching up with the thread. The issues have been completely solved by joevt's script and it 'sticks' as long as you have a battery and don't nuke the nvramrc, just like the sonnet patch, but better and universally for all similar 'bridge' cards.@cheesestraws was saying that booting from FDD was something he'd like to avoid. Was wondering if a purpose dedicated, tremendously simplified, read only version of BMOW's FloppyEMU setup would be a possible solution?
For TAM it doesn't matter, but for any other Gazelle machine it would be nice if they supported two FDDs for such purposes. I'm guessing not and hoping a bog simple EMU implementation might be scripted to eject/unmount itself to free up use of the single FDD available after it does the dirty?
Sorry if it's moot, haven't had a chance to re-read the project or even be able towrap my head around the goings on when/if I can make the time for review.
Is a battery required if you have AC connected? I guess it will be annoying when you get a power outage.Don't mind my question to cheesestraws, it is just me thinking out loud, with me not having a battery in my 6500.
No time and little understanding here, sorryHey @Trash80toHP_Mini, it's probably worth catching up with the thread.
I tend to think in terms of simple hardware hardware solutions that avoid problematic battery/power outage resets of systems.The issues have been completely solved by joevt's script and it 'sticks' as long as you have a battery and don't nuke the nvramrc, just like the sonnet patch, but better and universally for all similar 'bridge' cards.
Good to know there is a workaround for needing boot media of any sort to set things up to run properly at startup. My machines tend to sit around for long periods while I play with others or work out theoretical flights of fancy.Don't mind my question to cheesestraws, it is just me thinking out loud, with me not having a battery in my 6500. I'm not sure that anything floppy related is needed at the moment and think you have in mind when we were talking about running a longer script from a floppy disk as a possible answer. Joevt's script is way shorter, so this doesn't matter.
I think you got it, does my reply make sense to you?Does that make sense, or did I misunderstand what you meant?
Sadly I think it resets with every cold start, but not having a battery is really my problem, not the computer'sIs a battery required if you have AC connected? I guess it will be annoying when you get a power outage.
Nice video, @omgmonsters
At least the screenshot of my post on the screen had my attributions to you and joevt!Other than the fact that I created the patch application, not @Phipli ... it would be nice if people's work was accurately credited in youtube videos, although I know the youtube crowd is not fond of me.
