My Color Classic
Today I found my VGA adapter to try the monitor output of this card. I connected my LCD monitor, booted up, and here are my options:
At 640x480, I can display millions of colors. At 1024x768 it will display 256 colors.
Running my 22" as a second display on the Color Classic at 1024x768:
Do you happen to have the Extreme Systems software installer or can you upload the control panel and any extension here. ALL the copies of the software on MacintoshRepo, MacGarden, etc are corrupt. I cannot find them anywhere. I have the same accelerator but no software. I'm begging you to upload them here.
Best,
David
I am also trying to resurrect this card with no luck as all available links are corrupt.
does anyone out there have contact with @mikesworldus OR better yet, a working copy of the Impact 030 install files?
I found this on an old thread :
@Equill:
I'm in the same boat here, but I have good news! It turns out that you can use the MicroMac Thunder/ThunderCache Control Panel and it'll work perfectly with the Extreme Systems Impact '030. Grab version 1.2.3 here: http://web.archive.org/web/20080618014213/http://www.micromac.com/software/software.html
Cheers! :)
