Yosemite was the first Mac OS to support iCloud Drive. I was able to use "Get Info" on a folder inside iCloud Drive, tick "Shared folder", and have it show up in File Sharing on Monterey. Theoretically it should work that way in Yosemite as well. Unfortunately, I believe Yosemite requires 10.1 or later to connect to its AFP shares, so you'd need a bridge computer of some sort. If you use a sync software on, say, a Tiger machine to sync between a share on it and the Yosemite share, you could probably go all the way back to SSW 7.5.3.Does anyone know of a good way to save work on a classic mac that would then somehow seamlessly end up in iCloud? I have macs of all vintages… not sure what the oldest mac that can use iCloud Drive is. Thinking maybe some kind of synchronising software onto my new mac, I used to use one called Super File Synchoniser or something like that. Would be great to be able to access all my work without having to manually transfer stuff across and I’m sure I’d use my old macs a lot more if I could Do this
So this would mean: Tiger AFP has a shared location, say "iCloud", and your classic Macs put files on it. Tiger mounts the Yosemite iCloud share, and syncs files there.
