Video out SE/30 to VGA or HDMI
Hi, do you think it is possible to grab the board video out from a compact Mac and convert it to standard VGA ?
On J12 there are HSYNC/VSYNC/VIDEO. It should be possible to convert to VGA… I guess…
ideas ?
Thank you
Depending on your needs, you can use a RaSCSI to emulate a video adapter:
It's not built in to the main branch yet, and I haven't tried it, but it sounds like it should work
Adrian Black from Adrian’s Digital Basement on YouTube posted a video a while back on using a device called RGBtoHDMI to get video from a Mac Classic and convert it, believe it or not, to HDMI. It should work exactly the same for any B&W compact Mac if you tie into the correct signals.
Did anybody got this working on a Macintosh se/30? When I try to install the drivers, it says no compatible hardware found. When I check with SCSI Probe, I can see the radius. But no chance for installing the drivers
I still haven't tried it on mine - it sounds like it needs some reworking before they'll move it into the main branch, and I haven't bothered to switch branches to try it
Is the Raspberry connected to an external screen when you start the powerview service there? I guess It should be... I made it to have it working yesterday - now I have a second screen in a corner / portion of an old HP 1600x1200 LCD. It doesnt seem to change size tough, even if I select portrait screen in the driver dialog, and it doesnt get to fullscreen.
On the other side, adding the powerview feature kills the web interface of rascsi and you can only configure it via SSH -so not sure if this is worth keeping yet, probably not ready enough.
Thanks, I could live without the web-ui, since I am a linux admin, I don't care using the terminal, did you do that on an SE/30? Which System version you are on? Which driver for the powerviev? Thanks in advance
Yes, SE/30 with Bolle accelerator 😎.
I tested it on a System 7.5.5 installation, using Powerview driver recommended on the GitHub page (It says control panel v. 1.01). Now I am planning to test it on 7.5.3 and maybe other flavors of System 7.x too.
Ok, let's see. I try it now on 7.1, since I have no luck with 7.5.5. I can see the GPU in all known SCSI monitoring tools, but all 3 drivers I find complain about no fitting hardware installed
