upgrades for se/30
what upgrades are available for the macintosh se/30 and where can I buy them? The upgrades I know about but do not know where to buy are 8 16mb dimms, a accelerator, and a dos card. What other upgrades were available for this system and where can I buy them? Thanks for the help.
Depends what you are going to do with it. For me I tend to want an Ethernet card and 32MB of RAM plus external removable media (MO, tape drive, Jazz whatever). For OS 7.1 I never seem to need the 32MB of RAM I have so 128MB is a bit overkill (and I do have extra sets of 4x16MB 30 pin SIMMs on the shelf). SE/30's are not too slow for most software you would want to run on a low res B&W screen. If you have $100's burning a hole in your pocket then you could get a 68040 + greyscale adapter and whatnot.
The original SE is a bit slow so an accelerator is useful for those systems, but its a tradeoff between Ethernet and a CPU upgrade. One of my SE's has a 68030 upgrade (basically turned it into an SE/30) and external SCSI Ethernet, the other just has Ethernet.
Ebay seems to be the place for exotic upgrades, or you can ask around here in the wanted section.
MicroMac is no longer in business, the site is a zombie of a once great company.
Also, my ideal is the SE/30ecgs on Gamba's site, but with the accelerator on a socketed motherboard so it might all fit in the case. If that wouldn't work then the SE/30cgs with external Ethernet. Couldn't make a better compact than that if one tried.
MicroMac is not longer in business, and the current owner of the company does not have any more Diimo 030s.  Someone in Japan bought them all.
