Hi,
My first post here
Have just pulled out of storage my IIfx that was working fine when it went into storage a few years ago. The motherboard is very clean on it, no battery leaks or exploding caps (unlike the mb it replaced which *did* have a cap explode and was a horrible mess
) I just put in two brand new 3.6 volt batteries as the old ones were dead. Currently it seems to boot ok in the sense that the hard drive spins up and the noises it makes are consistent with the OS booting (see youtube video below.) There is no start-up chime but sometimes I get a single beep instead. Currently it has the HDD and one of the floppies connected, there's a pin missing on the mb connector for the second floppy so I assume that connecting that is likely to cause additional issues and therefore I've left it unplugged.
Things I've tried:
- swapping in a spare power supply from a Mac IIx that I have here (no difference to outcome)
- swapping in a different nubus video card (also from the Mac IIx) (again no difference)
- swapping the nubus slot for the video card (no difference.) It's worth noting that I also have a nubus network card in it as well and the green light on the card comes on when put in the same slots that the nubus video card does nothing in.
- swapping out RAM; it originally had 20 MB (4x 1MB in one bank and 4x4 MB in another) so I've tried putting both sets in bank A in turn and leaving bank B empty. But regardless of whether I use the 4MB set or the 16MB set the outcome is the same.
- re-seating the ROM card.
One thing to note; on one solitary occasion I did get the startup chime and it booted through to the OS cleanly with video. I have never been able to repeat this; obviously I just got lucky on that one occasion. But if nothing else it proves that the PC monitor and Lacie Mac-to-VGA adapter that I'm using are compatible (although I did try a second Mac-to-VGA adapter and a couple of different PC monitors anyway out of sheer desperation but no difference.)
Also worth noting is that although the hard drive noises suggest it is booting ok you can't shut it down by the power switch on the back, only start it. Interestingly this was also the case on the one time I managed to get it to boot with video.
So I'm beginning to think it's the motherboard itself that is the issue although I've no idea where to look next... Any thoughts?
Here's the video (sound is a bit quiet so you may have to turn it up to hear the HDD):
My first post here
Things I've tried:
