I've seen this once and fixed it by replacing the full display, maybe its the cable or something?
In this case it was not. like I said it was a failure in the logic board, it was not providing one of the required voltages for the display.
I will have to get pics with the details, but here is the root cause:
You are missing the twist voltage that drives the panel. its a 20 to 30v supply and its generated by the converter on the logic board. This voltage goes missing and that causes the black screen when the computer seemingly boots. Why? this boost converter sits right next to big ass leaker tank farms that need replaced and the electrolyte eats away the nearby components stopping the DC-DC boost converter from running.
No, they dont need replaced. they need removed and checked. to make sure they are still good and traces underneath are fine.
All three of them btw
Any updateI just got a new PB100 today, of course it does not start and has leaky caps.
So i'll recap a PB100 once again.
I've been lookin for one since a long time, as I've got a perfectly working one (recapped, bluescsi, etc) but it had red dead pixels due to trackball impact
This new PB100 I bought has a perfect screen, and is less yellowed...
I'll probably update my previous topic, it's likely I'll chose the replacement caps (even) more carefully.
Let me know if this group exists and when the next meeting is pleaseIs there like an AA for vintage enthusiasts to share their problems buying useless junk ?![]()
